2006 GSXR 600 LOTS of spares
Jester
Yamahawkins
Director
I bought this bike in the fall of 14, it was raced in AMA supersport. I have never crashed it and it runs great. Here is a video of the bike being ridden by a buddy of mine 2 weeks ago at summit main, the other bikes in the video are 750s.
The spare bodywork is Blue, could probably use a paint job but they would work fine if you aren't too picky.
Bike:
2006 Suzuki GSXR600
Fully wired and legal for AMA Pro/WERA competition
SS build on top end. 116hp engine
Penske triple clicker shock serviced over the winter by MDM
Ohlins 25mm cartridge in the forks with cap extenders serviced over the winter by MDM
Full Yosh exhaust
PC III USB
K&N air filter
Quick Shifter
ASV levers
GPR damper
Vortex rearsets
Woodcraft clip ons
Shark guard
Woodcraft sliders
Woodcraft clutch cover/slider
Woodcraft stator cover/slider
MotoZen gas cap
Vesrah brake pads
Fresh RK GB520XSO chain
Steel braided lines
Powder coated wheels
Alien Motion lightweight battery
90 degree valve stems
Motion Pro Throttle
Comes with LP front stand and Vortex rear stand
Spares:
Complete set of painted bodywork with windscreen
Fuel tank with tank cowl and quick release cap installed
Complete set of Powder Coated wheels with rotors(straight)
Complete set of forks(stock)
Shock(stock)
Radiator
Renthal clip ons
Front master cylinder
Rear master cylinder
Levers
Lower triple tree with stem and bearings
Grips
Tank guards
Throttle tube
Throttle cables
New clutch cable
Right side controls/kill switch
TiForce header
Stock exhaust header
New stator
New regulator/rectifier
Complete clutch ready to install(outer/inner basket,steels, fibers, springs, pressure plate, hardware etc)
Rearsets(stock)
Rear sprockets(43,44,47)
Front sprockets(14,16)
Spare x ring chain
Front and rear calipers loaded with pads and lines
Gauge cluster(undamaged and completely functional)
Starter
Front axle with spacers/bolt
Rear axle with spacers/nut
Shifter rod/linkage set up
Subframe
Clutch lever perch
Cooling fan
Cush drive
Stock gas cap
Misc Vortex rearset parts/pegs
Asking $5500 for everything.
TimTheAsian
Fresh off the Boat
Staff member
Bump for a nice bike and good seller.
That was some good footage Dan, I'm glad you kept Brandon behind you :D
anant puri
WTB Spares - Used bodywork, fuel tank+cover, front shocks+triple+stabilizer, rear-subframe and maybe a few other items but this is a starting list. Shoot me a good deal for all.
