KTM RC8RR and RC8R Limmited Edition Package Deal
tdelegram
KTM RC8RR and RC8R LE Package Deal $26,000. Pictures available on request via text or email.
2011 RC8RR Track Only Model:
1290 super duke cylinder and pistons rc8 head and crank, motor measures 1265. Built and tuned by Chad Wells at Commonwealth in Louisville. Currently tuned on T4 did 166/98 on Chads dyno which is conservative. Full KTM club kit installed (akra titanium exhaust, bmc air filter, thinner head gaskets, re-timed cams). The motor has about 5 tanks of gas through it as it’s primarily a Novice coaching bike, and I am too cheap to coach on T4. Yoyo slipper clutch, WSB spec transmission from HMC, last in USA left over from AMA campaign, factory pro shift star and spring. Nemesis TC/Wheelie control with on the fly adjustment. BST carbon wheels with captive spacers new sc3 rear good sc2 front. Ohlins FRGT forks and TTX shock set up and serviced by Thrermosman for 200 pounds, Ohlins steering dampener. Bar ends milled to accept woodcraft lever guards, quick turn throttle, rottweiler intake. Folding levers, light weight battery, BMC frame sliders. Safety wired for wera/ccs. This is the dedicated track model and can not be made street legal, it also has case guards, relocated parts, keyless ignition and several other things that make it different than the street going model.
Extra’s include:
  • 4 sets of Marchesini forge aluminum wheels with rotors (new front rain/used rear rain, used front street/used rear street, one set nothing mounted last set unknown)
  • Full set of factory body work painted
  • Several sets of factory rear sets
  • Extra folding brake and clutch levers
  • Extra set of milled bar ends for woodcraft lever guards
  • Full extra HMS quick shifter set up
  • Endurance tank with pump (Italian aluminum tank, same shape as stock)
  • Nemesis TC maps for multiple tire brands and size
  • Woodcraft clip-ons
  • Multiple sets of rear sprockets
  • May be some partially used brake pads
  • Stock non-slipper clutch
  • 2 sets of pitbull pins
  • Stock street front and rear pegs
  • Several sets of front and rear axle sliders
  • Stock underslung exhaust
  • 2 Akra decibel killers for akra exhausts
  • Extra wind screen
2010 KTM RC8R Limited Edition Akrapovic edition, #22 of 25 in the USA approximately 5k miles with factory racing rear sets, factory pro shift star and spring, new street tires, light battery, all 3 keys, rear seat and also KTM rear bag, bazazz zifi quick shift fuel and traction control, fender eliminator. Bike was low sided at t5 at Barber, plastics left side are rashed as is bar end all cosmetic. Full club kit installed as above.
Track bike can be seen at most northern N2 days, will try to post up some pics.
Both bikes have PA titles
tdelegram
Street bike
tdelegram
Track bike
