WTB Brembo master cyl part
Motofun352
Help a brother out....If you got an old busted up Brembo MC...I need the cross-drilled barrel that connects the brake lever to the threaded plunger. Let me know what you got. Many thanks.
Motofun352
I also found out that the Brembo MC only accepts banjo bolts with fine threads. The standard banjo bolts that EVERYONE else uses are course threads...so now I also need a "Brembo" banjo bolt for a single banjo fitting.....Buehler?
vinny337
Vin is in...Beastmode!
Try Kurvygirl, she had one that fit mine I had to exchanged because of the Galfer brake lines.
I'll look around and see what I have. If Kurveygirl doesn't have them, contact Fred at yoyodyne. Depending on the Brembo and the type of brake lines, the supplied bolt that comes with the RCS version may be too long.
Motofun352
thanks, I bought new from Kurveygirl.....I don't know why Brembo stuff is so expensive, must be made of gold.:wow:
