!ThatGuy!
See ad for updated info: https://weraclassifieds.com/ads/06-gsxr-600/#comment-35916
2006 GSXR 600
5968miles on clock, but speedo is not functioning. I have salvage title in hand. The frame was swapped this past race season by myself and a professional mechanic. The bike has been down during races, so it has the battle scars, but everything is mechanically sound and everything is straight (except for left clip-on bar, it has a slight bend and fairing stay which I am replacing). I religiously change the oil with AMSOIL synthetic. I just winterized the bike so has new oil, anti-freeze, and clean/lubed chain while on battery tender. Located in Staunton, VA. Please contact me at: scracing200@gmail.com
Pics: http://imgur.com/a/iG8c7
Now for the goods:
The Bike:
•Supersport Motor build by Markbilt (March 2012) (From their site: R&R engine, blueprint, radius valve job, deck head & cylinder, degree cam, replace rod & main bearings, tune)
• Drilled / wired to CCS spec
• 520 Conversion with Vortex front/rear sprockets and DID chain performed in 2014 • Keyless ignition
• ¼ turn Vortex gas cap
• Forks refreshed in 2014 by a professional mechanic
• Traxxion extended Showa fork caps
• Traxxion Omni fork spring buffer kit
• TITANIUM!!! Full Leo Vince Factory R “Corsa” exhaust
• PCIII and PC Ign Module with RnR tune performed in 2014, tuned for pump gas
• PC Quick Shifter in GP pattern
• K&N air filter
• FP Racing brake lever
• Goodridge SS brake lines up front
• Vortex Clips ons
• Vortex Rear sets
* Vortex fairing stay
• Woodcraft case and clutch covers
* Stomp grip
* SET Valve mod
* Secondary Butterfly Valve disks removed (sensor and rod still in place, but shows FI light, does not effect performance, I had RnR verify)
• Lightened rear rotor
• Vesrah SRJL XX brakes
• Rear brake reservoir delete
• Moto-D magnetized oil drain bolt
• Vortex swingarm spools
• Frame slider on Right side only (left side came off in a crash and I have not replaced it yet)
*Spark plugs replaced 2014
*Compression test done in 2014 and passed
2006 GSXR 600
Now for the goods:
The Bike:
• K&N air filter
• Vortex Clips ons
• Vortex Rear sets
* Stomp grip
* SET Valve mod
