bons
2001 Honda 600 F4i track bike, the bike is equipped with:
Clear Title in hand
HotBodies race plastics
Power Commander with Micron map (no serial cable)
Micron slip-on exhaust
Pazzo shorty levers
HH front brake pads
APE manual CCT
Michelin Pilot Power tires
Stock suspension
Oil drain plug, filler cap and oil filter are safety wired.
I also have most everything you need to make the bike street legal, stock fairings (busted up from original owner), headlight assembly, rear seat, Haynes service & repair manual and other miscellaneous spare parts.
The bike has been down 2 times; once at Summit Main turn 1, mostly cosmetic damage to the fairings also bent the rear brake lever which has been replaced and snapped the front brake lines which have also been replaced with metal braided lines. Second was at Summit Jefferson, low speed run off in turn 1 and low sided in the grass, only thing damaged was the tail section; all fiberglass work was done by me (first few times are never pretty) so its not the best job in the world but it is a track bike. The tank has a small dent on the left side and a larger dent on the right side.
The bike has 17,000+ miles on it and runs great, the motor is strong, the oil is fresh and the bike is ready to go.
First $2500 takes it and the price is firm. I am located in Warrenton, VA.
Email chrisbons@gmail.com with questions.
Clear Title in hand
Pazzo shorty levers
HH front brake pads
APE manual CCT
Stock suspension
