Son of Sam
As the title states, I'm parting out my 08 R6. The bike had a good life and was well taken care of...
Note that the prices do not include shipping. For smaller items I will ship within 2 business days of cleared payment (in most cases it will be within 1 day). Bigger/ heavier items may take a day or two longer. I'm located in Northern NJ and I'm willing to meet or even deliver within reason (particularly the larger/bulky items).
You can PM me or contact me at 201 six seven nine - two zero two four (text preferred...I do have a day job) or email salbert14 at gmail dot com.
I have pictures of everything here...
https://drive.google.com/open?id=1gu-3gNRveWDgUmTT3d89fLHGRPLH7iM_
If you're having trouble seeing them or want me to email you any pics - just reach out.
Frame (w/ clean & clear title) $1,500
Motor (w/ 11K miles [4K street miles] and brand new trans [I have all old parts & paperwork]) $1,500
Forks w/ Ohlins 30 mil kit (.925 spring rate) $1,100
Subframe $175
Swingarm (has wear mark from boot on right side) $100
Red/Black Full Bodywork painted by Andrew Swenson (w/ Zero Gravity windscreen) $625
Blue Upper/Lower painted by Andrew Swenson (w/ Zero Gravity windscreen) $450
2 Tanks (1 black / 1 blue – both come with shroud, tank sliders & stomp grip [price is for each]) $325
Shark Skins seat w/ Graves foam $75
3 Front wheels (2 white / 1 black – all 3 come with rotors [price is for each one]) $100
1 Rear wheel (white with rotor and sprocket carrier & cush drive) $175
1 Rear wheel (white with rotor and NO sprocket carrier or cush drive) $150
1 Rear wheel (champagne WITHOUT rotor and NO sprocket carrier or cush drive) $125
Woodcraft frame sliders (w/ extra puck) $40
Cluster gauge (approx. 11K miles) $200
Gear indicator (Missing face panel but works. Can get a new one from Starlane for a couple dollars) $25
Vortex rearsets (w/ two extra pegs – one slightly rashed) $275
GPR steering stabilizer $250
CABS (w/ Pull Quick Shifter [It was rewired to work w/o need to pull clutch so selling it w/ pull QS]) $375
DynoJet Quick Shifter (Push) $125
ECU $200
PC3 (will bundle PC3 & ignition module for $125) $75
Ignition Module for PC3 (will bundle PC3 & ignition module for $125) $75
Fairing Stay $25
Radiator (w/ fans) $125
Brake lines (not sure of brand [were on bike when I bought it] have a few nicks in rubber casing) $50
Calipers (price for set) $75
Triple tree (upper) $50
Triples tree (lower stem bracket) $125
Motion Pro Quick Turn Throttle $85
Woodcraft clip-ons (w/ bars) $85
Airbox (complete) $75
GYTR Slip on (also have MJS headers if interested) $125
Throttle bodies $50
I also have a few OEM parts so if you need anything, just reach out - you never know, I may have what you need.
Subframe $175
ECU $200
Fairing Stay $25
Throttle bodies $50
