padilla6144
2013 Ducati 1199 'R' - $15,500
This bike is absolutely a monster. The “R” gets an updated engine management system and recalibrated ride-by-wire- throttle, titanium con-rods, a lighter crankshaft flywheel and dlc-coated rocker-arms, 4-point adjustable swingarm pivot, fully adjustable Ohlins suspension managed by Ducati Electronic Suspension (DES), aluminum gas tank all of these with 200+ Horsepower with 100+ lb-ft of torque.
Bike is in great conditions, NO mechanical, engine or transmission issues.
A few minor scuffs here and there for a bike its age and mileage, no dents anywhere.
No Desmo Service has been done as it’s not needed yet. Desmo is due at 15,000 miles and the bike has less than half of that.
www.facebook.com
- VIN: ZDM14BPW9DB011513
- Clean/Clear Maryland Title on hand
- Located in Westminster, MD 21157
- Mileage: 6,588 as of 2/20/26 (season about to start so it may go up slightly)
- 1 Key
- Ducati Riding Modes: Race, Sport, Wet
- Ducati Traction Control (DTC)
- Ducati Engine Brake Control (EBC)
- Ducati Ride-by-Wire (RbW)
- Ducati Quick Shift (DQS)
- ABS
- Termignoni Full Titanium Exhaust System
- Ohlins FNIX30 43mm with TiN, fully adjustable usd Front Forks
- Ohlins TTX36 fully adjustable Rear Shock
- Ohlins Steering Damper
- Brembo Master Cylinder
- Brembo Front Monoblock M50 4-piston calipers with dual 330mm Brembo disk
- Brembo Rear 2-piston caliper with a single 245mm disk
- Marchesini Forged Alloy Wheels
- AR Folding Levers
- Panigale Tank and Side Pads
- Battery Tender Terminal
- K&N Air Filter
- Pirelli Diablo Rosso III Tires
- TailTidy Fender Eliminator with LED Signal Lights
- Frame Sliders (Not Installed – Brand New)
- Rizoma Pegs
- TWM Carbon Fiber Quick Release Gas Cap
- CNC Rearview Mirror Blocks (not installed – Brand New)
- Carbon Fiber Ducati Clutch Cover
- Carbon Fiber Heel Guards
- Carbon Fiber Exhaust Cover
- Carbon Fiber Swing Arm Cover
- Carbon Fiber Suspension Spring Cover
- Carbon Fiber Air Ram Cover
- Carbon Fiber Ignition Switch Cover
- GoPro/Ram Ball Mount
- Universal Motorcycle Cover
- Universal One Sided Rear Stand
2013 Ducati 1199 Panigale ‘R’
2013 Ducati 1199R $15,500 Read it correctly, this is an ‘R’ model, not a base, not an ‘S’, but the ‘R’. Would consider a trade only and only for: 1. BMW S1000RR (2020+) 2. BMW S1000R (2020+) 3....
