I've done our best to price everything fairly but if you feel something is priced wrong please PM me and we can work on the price. Everything was removed from a 2016 Ducati 959 Panigale with 1800 miles. Prices do not include shipping. If there is anything you don't see listed PM me and I'll check availability. I ship within 1 business day of cleared payment, unless its a bigger/ heavier item which could take up to 3 days. You can contact me here, call/text 703-565- three one three one or email emerson at bobbleheadmoto dot com
Aftermarket parts
* Ohlins 30mm Cartridge kit with forks 1400 or 900 plus your forks
* Ohlins TTX shock $900
* Akrapovic Titanium Full exhaust $1900
* Ohlins Steering damper $275
* Woodcraft rearsets $300
* Woodcraft clutch guard $60
* Sato frame sliders $120
* Ducati Performance seat $100
* GB shark fin $40
* SS Lines front $60
* Sprint air filter $60
OEM parts
Frame Salvage title $2000
Engine $1500
Ignition/dash/ecu $1000
Clutch master $125
Brake master $125
Clip on (left) $50
Subframe might be a bit tweeked $50
Wheel set $1000 (comes complete with everything, rotors, sprocket carrier etc)
Head light switch $125
Throttle bodies $150
Fuel pump $100
Wire harness $135
Coils $60 set
Calipers front set $250
Caliper rear $120
Cooling Fan $50
Rectifier $50
Shock linkage $70
Axle Front $125
Axle rear $25
Swing arm $300
Rear fender $10
Radiator $170
Radiator lower $150
Gas tank Damaged $100
Quickshifter $125
Aftermarket parts
* GB shark fin $40
OEM parts
Engine $1500
Clutch master $125
Brake master $125
Clip on (left) $50
Fuel pump $100
Wire harness $135
Coils $60 set
Caliper rear $120
Cooling Fan $50
Rectifier $50
Shock linkage $70
Axle Front $125
Axle rear $25
Swing arm $300
Rear fender $10
Radiator $170
Radiator lower $150
Quickshifter $125
