Selling the bike I used to coach on for $4,500. The spring rate is for a 250-lb rider, so most riders will want to replace the springs.
Braking System
Braking System
- Spiegler Front & Rear Brake Line Kit
- Galfer Front Wave Brake Rotor
- EBC Double-H Sintered Metal Front Brake Pads
- Speed Bleeder Motorcycle Brake Bleeder Screws
- Brembo RCS14 Radial Brake Master Cylinder
- TST OEM Rear Brake Reservoir Delete Kit
- Vortex V3 2.0 Gold Chain and Sprocket Kit - GFRS Kit w/520SX3 Chain
- TST Captive Chain Adjuster & GP Lifter System
- Ohlins STX46 Hypersport Rear Shock
- Ohlins NIX22 Cartridge Kit
- MWR Race Air Filter
- TST WORX Velocity Stacks
- TST WORX Airbox Cover
- Yoshimura Full System Exhaust
- TST WORX Smog Block Off Plate
- TST WORX Stage 2 ECU Tune
- Translogic QSXi Intellishift Quickshifter ECU
- Aliant YLP Series Lithium Battery
- Motion Pro Enhanced Right Side Start/Stop Switch
- Motion Pro Rev3 Throttle Kit
- Renthal Kevlar Reinforced Road Race Dual Compound Grips
- Vortex V3 2.0 Rearsets
- Vortex V3 2.0 Frame Sliders
- Woodcraft Wide Coverage Toe Guard Kit Shark Fin
- Woodcraft Clutch Cover Protector with SS Skid Plate
- Woodcraft Stator Cover Protector with SS Skid Plate
- TST Industries Captive Wheel Spacer Kit
- Sutter BTL (Back Torque Limiter) Slipper Clutch
- Armour Bodies Yamaha R3 Supersport Kit
- CRC Fairings Seat Complete (Seat Unit, Seatpad, Seat Support)
- TST Mirror Block Off Plates
- Hiflofiltro Racing Oil Filter
- Title
- Heavy Duty Shift Detent Spring
- Dunlop Rain Tires
- Side stand
- TRS Locking Pins
- TRS Triple Tree Pin
- OEM Rotors (used)
- OEM Rotor Bolts
- Brembo brake lever
