tittys04
After flipping the bike last year and bending my key pretty good, I finally decided to go with a keyless set up. I've done some digging and can't find exactly what I'm looking for, although I have gotten some idea as to what I need.
I initially thought I would be able to just connect a toggle to 2 wires and be done with it, but my 600rr has a little pink wire, that in the diagram, shows it going to the ecm, but tells me no other info about it.
I've been seeing people say something about a 100ohm resistor, but I'm not exactly clear on what needs to be done. I know the red and red/black wire are the 2 that will get connected by the switch, but what exactly do I need to do with this pink one? Is 100ohm the correct value? Do I connect the other end of the resistor to a ground, or to one of the power wires? Thanks for your help guys.
