New bike break in?????
Unbroken13
Hey chuck... I'm picking up a left over brand new 2010 r6... Was wondering about break in period... Do I need to baby it for a few thousand miles ???
Lonewrench
Absolutely not, get it warm and run it in hard as you want to. rpm's,high ones promote ring seal and that in turn promotes compression and less,a lot less blow by. just make sure the clutch cover is warm to the touch before flogging. Taking it easy is a big mistake,and ive run more than a few engines in too:wow:
erick1670
:agree:
I was about to tell you the same...
If you braking it on the street, change the oil & filter (keep your receipt, for warranty) after 200-300 miles of hard riding, then when you get your 600 miles service. If you braking it at the track, do all 3 morning sessions then at lunch change you oil & filter, then at the 600 miles service.
I broke in mine at the track and did the 3 sessions then the oil & filter change... I stay 2-3000 rpm's under the red line :D
