New Project....2014 636 Engine swap into 2009 ZX6R
Evil Cupcake
With thoughts to do a superbike build on my 2009 ZX6R, I tossed around a few ideas for reliability and a solid 125+ hp. After speaking with KWS in Charleston, SC, I decided to pick up a friends 636 motor that came out of his wrecked 2014 ZX6R with a mere 56 miles on it.
I will be using the 09 airbox, 09 harness, injectors and Throttle bodies. For the ECU, I am using a Kawi Kit ECU with a Dynojet quickshifter.
KWS will put a little love in the bike with tuning, a little shave of the head, adjust the cams and a thinner gasket.
Since the motor is essentially the same the swap should be fairly straight forward. Since I am using the 09 harness, no need to worry about the Traction Control. For the gearing internally, I am debating about pulling the clutch and transmission from the 09 since I actually like the slipper better in the 09 over the 13.
Pics to come...
Otto Man
John
You might as well have him ride too...you sure you can ride that much without straining your neck from holding up that dome of yours for so long??
