Parting out Josh Herrin's 2008 Graves R6 and a Farrel Performance R6
Emerson
BobbleHeadMoto
ATP/3C
I know... I know.... I shouldn't do this.... But I'm super excited to have this gem and provide you guys and gals with the best parts available. I've done mybest to price everything fairly but if you feel something is priced wrong please PM me and we can work on the price. Prices do not include shipping. I ship within 2 days of cleared payment. You can contact me here, call/text 703-565- three one three one or email emerson at bobbleheadmoto dot com
Aftermarket parts
Ohlins 25mm kit extended 10mm $1300 (2 weekends on refresh)
Ohlins TTX shock $800
Ohlins Steering damper with Graves mount $450
YEC ECU and modified harness $650
Penske triple clicker $800 (2 weekends on refresh)
Graves Motor Rebuilt by RnR Cycles (8 days on rebuild) $2200
Graves clip ons $100
Graves Rearsets $300
Cox radiator guard $60
Tighttails Subframe NEW $386
Tighttails Fairing Stay NEW $148
Armour Bodies Race bodywork NEW $550
Armour bodies Bodywork USED $500
Sharkskinz Bodywork New $1055
Sharkskinz bodywork used (damaged) $350
Sharkskinz Seat base with Graves seat pad $150
Sharkskinz Seat pan NEW $183
Brembo billet calipers $1000
Brembo RCS $200
Brembo Clutch lever $120
Braketech iron axis rotors $400
Braking rotors $325
Woodcraft Case covers (left and right) $250
Graves case cover (timing) $75
Flashed ECU $225
Motion Pro throttle Rev2 $85
Dynojet Quickshifter $150
BMC air filter $40
K&N Air filter $40
GB frame sliders $45
PCV $150
PCV Quickshifter module $90
PCV Auto tuner $200
PCV dual map switch $20
Exup eliminator $30
PC3 Ignition module $100
Woodcraft rear master spring kit $10
SS brake lines front $60
SS brake line rear $20
Calipers with Versrah pads $100
Bazzaz Zfi/QS/TC $500
Bazzaz Map/TC switch/Dial $80
Bazzaz TC light $50
Bazzaz Auto tuner $175
Driven chain adjusters $75
LIghtweight battery $80
Puig smoke windscreen $60
Lightweight rear rotor $40
OEM parts
Frame 2009 Clean and clear title $1500
Frame 2008 clean and clear (re-stamped by Graves) $1000
Frame 2008 rebuilt title $800
Forks $300
Clutch lever perch $15
Subframe $150
Fairing stay $80
Gas tank bracket (sides) $20
Gas tank Brakcet (rear) $30
Wheel set $375 (comes complete with everything, angled valve stems)
Lower triple tree 08-16 $125
Lockset $100
Windscreen $30
Head light switch $40
Kill switch $20
Tank side pannels $25 ea
08-09 Air box $100
10-15 air box $50
06-07 Air box $30
Throttle bodies $25
06-07 Fuel pump $40
08-09 Fuel pump $70
08-16 Wire harness $50
06-15 Sub harness (to dash) $40
Seat $30
06-07 ECU $100
08-15 ECU $150
Coils $50 set
Front master cylinder $100 (with lever)
Rear master/caliper $20
Radiator $125
Cooling Fan $10
Calipers set $75
Rearsets $25 ea
Rectifier $40
Clip on $25
Axle $15
Chain Adjusters $25
Rear fender $10
22140959_1047891898646857_4168707243436466648_n.jpg 22181292_1047799791989401_1127543547818043007_o.jpg
Eloy Cruz
Hi, would you happen to know if the graves clip ons fit a 2007 r6r? I’m also interested in the woodcraft rear master spring kit and the GB frame sliders. Thank you.
Emerson
BobbleHeadMoto
ATP/3C
Yes the clip ons and spring kit will work. The GB sliders are sold.
