DUNLOP-RTS
Dunlop currently has 4 usable tire choices for track days -
Q2
D211GPA
D211GP
N-Tec slicks.
Q2 is the top of the line sport/street tire. Excellent for street riding. You can use it for your first couple of track rides, but the moment you start to get with the program you will want to step up.
The D211GPA is the spec tire for the AMA. it is lower cost, and is a great all around tire. The AMA guys are right on the track record with this tire and there is no reason you can't go very fast on it. Use the Med front and rear compounds for track days.
The D211GP UK N-Tec, this tire will cost you more, about $125 more than D211GPA. It is good for about 0.5 seconds per lap faster than the D211GPA (depending on the track, may be less at some tracks). This tire will last longer than the D211GPA and you will get more competitive laps from this tire. The increased cost is about the same as the increase in laps. Its a toss up if you are looking at the laps/cost issue. you need to try them both to determine on your bike which is the best bang for the buck.
The N-Tec Slicks. Top of the line. Nothing available is better, and I mean NOTHING IS BETTER. This tire will last longer and grip better, for more laps, than anything available.
All these tires are great choices for track days. You can't go wrong with any of them. I recommend to start at the top (Q2 or D211GPA) and if you like it stay with it. If you desire more as a rider, then step up to the next tire.
BTW: the lower 3 tires have the N-Tec construction, the D211GPA does not use the name N-Tec, but is still the N-Tec construction.
Beginner groups: I would stick to the D211GPA and keep it simple. Put in lots of laps.
