Yamaha R6r Race/Track Bike Supersport Built Level II
Hawaiif4ii
$7800
Engine
Full engine build with ’13 spec components built to the extent of the AMA, WERA, or CCS rule book
Dyno tested at 123hp of 93 octane pump gas, 128hp and 49.9 ft lbs of torque on VP MR12
Highlights include:
Bazzaz engine control unit with quickshifter and two-mode map toggle switch on left handle bar
Blueprinted, CNC Pro Head, degree’ d cams, Millennium Technologies Block Bore and Plate, CNC Ports and Newan CNC Radius Valve job, deck head and cylinder, degree cams, clearance all bearings
Modified slipper clutch
BMC race filter
$6,418 total invested into the engine all work documents included
Chassis
Suspension built and set up by Ohlins USA, by AMA rep Mike Fitzgerald AKA Thermosman
25MM OHLINS Cartridge Kit (.95 Springs)
OHLINS TTX rear shock (.95 Spring)
SBK FACTORY EVOII FULL SYSTEM TITANIUM exhaust
New full body work done in World Supersport Monster Energy Sponsored Livery
Brand new windscreen
GPR V4 Steering Damper (just freshened)
Woodcraft Rearsets, Clip On’s, Spools, and frame sliders
Wood Craft Case Covers with removable/replaceable stainless steel plates
Vortex 520 chain with Sprockets T15, 16, 45, 46, and 47
Spiegler stainless steel braided lines
Pirelli Supercorsa SC1’s with plenty of tread left
Versah RJL pads
Full safety wired with speed disconnect clips
Extras
Second set of wheels with bearings and brake rotors with Dunlop 211 GPA’s (two practice sessions of wear)
Rear ride height adjustment shims
Vortex sprockets T15, 16, 45, 46, and 47
One set of front Versah RJL brake pads
Extra clip on
Extra front fender
Extra upper fairing
Bill of Sale
If you want all original engine parts can be included. Head, valves, pistons, etc.
This is one fast well set up bike. It’s making what an AMA Daytona Sportbike makes (123hp) just on pump gas. If you are a track rider just run the toggle switch in the down position and run pump gas. Want to race? Flip the switch and put in VP fuel.
$7800
Bike may be delivered within 50 miles of the Northern Virginia/DC area
PM or Email:
Yerfdog59 at aol.com
upload_2014-10-22_14-42-17.jpeg upload_2014-10-22_14-42-53.jpeg upload_2014-10-22_14-44-1.jpeg upload_2014-10-22_14-45-37.jpeg upload_2014-10-22_14-47-6.jpeg
