08 R1 windscreen and Race bodywork
TGRIFF
May 20, 2011
68
Any tips out there for mounting the windscreen on an 08 R1 with some new Armour Bodies. It appears to have only 2 mounting points at the top and nothing to hold the bottom in.
slow50
Jun 17, 2010
6
I am not 100% I understand your question. I believe you mean you are missing some of the windscreen holes in the upper fairing. I have seen bodywork that just has a few holes predrilled and other bodywork that has no holes. I have an older R1 but I just took my windscreen and used blue painters tape to hold it in the correct position. Then I used a stepped drill bit to drill any missing holes. Hope that helps...
TGRIFF
May 20, 2011
68
The stock wind screen has 2 mounting bolts at the top o either side and then the lower part of the windscreen just 'slots' into tabs on the OEM bodywork. The armor bodies does not have these tabs.
lindr6
Jul 14, 2008
156
You must drill them in ur self to the windscreen and body work. I have a 07 I drilled 4 holes and used regular windscreen screws and rubber well washers.
