SOLD!
SOLD!
SOLD!
2000 SV650 Superbike $3200 Or possible trade for 600
Championship winner
Under 330 lbs!
Clean and clear title in hand
Suspension:
’04 GSXR 600 front end with 1.0kg springs
Penske Double Clicker rear
Engine:
Dyno'd @78 hp before intalling BMC filter
2mm JE hi compression pistons (677cc)
Cam swap mod
Spears cylinder stud kit
Factory Jet kit
BMC race filter
Mild intake port cleanup
M4 exhaust
Super light 2.5lb ignition rotor & starter sprag - Retains charging with special hi temp neodymium magnets
Barnett Clutch
Woodcraft billet clutch cover
Race wiring harness (no electrical components located in the subframe)
Li Fe 8 cell battery relocated beside the engine
MOSFET voltage regulator conversion
Keyless start (operated by kill switch)
Chassis:
Lightweight modular aluminum subframe
NHK adjustable steering damper
Woodcraft rearsets with folding shift lever and custom folding brake lever
Shorty front brake lever
EBC pads - All the brakes you’d ever want and they’ll last a couple of seasons
Stainless brake lines
Aluminum fairing stay
5.5” Marvic Penta magnesium rear wheel with TGR drive cushions
Airtech Aprilia RS250 upper
Custom belly pan
Sharkskinz supersport tail
Cut-down stock seat and full thickness seat
Frame savers
Swing arm savers/spools
Custom 5 gallon tank with dry break (available)
Custom lightweight rear tank mount
Upper triple custom machined for proper ride height
Custom captive rear caliper mount- eliminates torque arm and makes wheel changes super easy & quick
Mychron 2 dash
520 chain and sprocket conversion 15 & 16 tooth front / 45 & 47 rear
Pirelli Supercorsas 120/180 with plenty of life left
Crash spares. levers, bars, etc
This bike has been an awesome racebike for me, one of the best I've owned (and I've owned a bunch) and I'd keep it around if I could afford two racebikes. However, I've wanted a 250 gp bike as long as I've been racing so I'm selling it to make room for a two-smoker.
Complete spare low mileage engine and other engine spares available
email: timmgold AT yahoo dot com or call: seven one six 706 - Eight six two five
Located near Buffalo, NY
SOLD!
SOLD!
Championship winner
Under 330 lbs!
Suspension:
Engine:
Cam swap mod
Factory Jet kit
BMC race filter
M4 exhaust
Barnett Clutch
Chassis:
Custom belly pan
Frame savers
Mychron 2 dash
