I've done my best to price everything fairly but if you feel something is priced wrong please PM me and we can work on the price. Prices do not include shipping. I ship within 1 business day of cleared payment, unless its a bigger/ heavier item which could take up to 3 days. You can contact me here, call/text 703-565- three one three one or email emerson at bobbleheadmoto dot com
I have hundreds of Hi res pictures that you can see on my facebook page or I can email.
www.facebook.com/bobbleheadmoto
Aftermarket parts
Ohlins 30mm cartridge kit with forks $1100 or $900 plus your straight forks
Ohlins TTX Shock $900 (Zero Miles since refresh)
Graves Full SS exhaust $700
Graves Upper shock bracket with captive nut $50
Graves Exup Eliminator $50
Graves Progressive Throttle with modified Housing $100
Graves rear brake return spring SOLD
Graves Clutch frame slider $60
Euro Racing Quick turn Throttle $100
Yoshimura full SS Exhaust $550
YEC ECU with YEC Harness $900
GPR V4 Damper SOLD
Vortex clip ons $95
Woodcraft Rearsets $250
Woodcraft superbike liferters $70
Woodcraft Axle sliders front and rear $90
Woodcraft Frame sliders $55
Woodcraft Frame sliders a little rash $40
Woodcraft case cover (timing) $75
Woodcraft Brake reservoir bracket $12
Woodcraft Toe guard $30
Vortex Rearsets $150
Lightech Brake and clutch levers with Master cylinder $225
Tighttails Subframe NEW $386
Tighttails Fairing Stay NEW $148
Sharkskinz Superbike Bodywork USED SOLD
Sharkskinz Bodywork New $1055
Sharkskinz Seat pan NEW $183
Brembo Clutch lever and perch $100
Braking rotors $275
Gi Pro gear indicator $80
Flashed ECU $225
K & N filter $30
PCV with O2 optimizer $160
PCV O2 Optimizer $30
PCV Quickshifter expansion module $75
PCV Auto tuner $150
Dynojet Quickshifter $150 (PULL and PUSH)
PC3 Ignition module $100
SS brake lines front $75
SS brake line rear $25
Calipers with race pads $100
Bazzaz Zfi/QS Push sensor $250
Bazzaz Auto tuner $150
LIghtweight Shorai battery $80
Lightweight Pulse battery $60
Puig smoke windscreen $60
Puig Clear windscreen SOLD
Captive caliper bracket $75
Kickstand eliminator bracket $40
Markbilt Captive spacers (front only) $40
520 DID Chain and Driven sprocket kit $80
Superstock Engine with 2 light seasons $1500
Cox Radiator Guard SOLD
GB Case covers $100
Evoltech Gas cap $80
Vortex Gas cap V3 $70
OEM parts
Frame 2009 Clean and clear title $1400
Frame 2008 Clean and Clear title $1300
Frame 2008 Clean and clear MSO $1200
Frame 2008 rebuilt title $800
Dash/Speedometer $225
Clutch lever perch $15
Lower triple $150
Forks $350
Subframe $150
Gas tank bracket (sides) $20
Gas tank Brakcet (rear) $35
Wheel set $350 (comes complete with everything, rotors, procket carrier etc)
Lockset $100
Headlight $140
Head light switch $40
Kill switch $20
Tank side pannels $25 ea
08-09 Air box $100
06-07 Air box $30
Throttle bodies $50
06-07 Fuel pump $65
08-09 Fuel pump $70
08-16 Wire harness $30
06-15 Sub harness (to dash) $40
Seat $30
06-07 ECU $125
Coils $40 set
Front master cylinder $100 (with lever)
Rear master/caliper $20
Radiator $125
Cooling Fan $20
Calipers set $75
Rearsets $30 ea
Rectifier $30
Clip on $50
Shock linkage $25
Axle $15
Chain Adjusters $25
Rear fender $10
Aftermarket parts
GPR V4 Damper SOLD
Vortex clip ons $95
Braking rotors $275
Flashed ECU $225
K & N filter $30
PCV Auto tuner $150
GB Case covers $100
OEM parts
Lower triple $150
Forks $350
Subframe $150
Lockset $100
Headlight $140
Kill switch $20
08-09 Air box $100
06-07 Air box $30
Throttle bodies $50
06-07 Fuel pump $65
08-09 Fuel pump $70
Seat $30
06-07 ECU $125
Coils $40 set
Radiator $125
Cooling Fan $20
Calipers set $75
Rearsets $30 ea
Rectifier $30
Clip on $50
Shock linkage $25
Axle $15
Chain Adjusters $25
Rear fender $10
