Poper
2013 Aprilia Tuono V4
72xx miles
Baldwinsville, NY 13027
$8,500
Suspension
Ohlins NIX30 carts (1.1)
Ohlins TTX shock (upgraded valving, 140)
(fresh service, 10/2018)
Ohlins steering damper
Brakes
Brembo RCS19 master
Brembo calipers
Brembo disks
Vortex carbon pads
Steel lines
Motul fluids
Controls
Woodcraft rearsets (GP & STD)
MotionPro Quick turn throttle
CRG short clutch lever
APRC traction, power, launch, wheelie controls
Stomp grip
Rizoma drag bar (lower)
Rizoma bar end weights
New grips
Crash protection
Woodcraft case savers (both sides)
R&G frame sliders
R&G swinger sliders
Rad/oil guards
Engine
Arrow exhaust slip-on
Race ECU
K&N air filter
NGK spark plugs
PSR blockoff plates
Aluminum coolant manifold
Samco coolant hose kit w/Samco clamps
MotionPro overflow can
520 kit (Driven, DID, -1,+1)
Gilles Tooling shift shaft holder
HighFlow oil filter (+1)
Magnetic drain plug (+5 washers)
Castrol full synthetic oil
Race tail, number plate, Water wetter, 90* valve stems, safety wired, ready to go!
Valve check complete @ 6,500 miles with all in spec (documentation provided).
Salvage NY title from minor street crash in 2017. I’m the original owner.
Ideal for a rider who wants all the performance with more comfort.
Mike
(315) 214-1958
72xx miles
$8,500
Suspension
Brakes
Brembo RCS19 master
Brembo calipers
Brembo disks
Vortex carbon pads
Steel lines
Motul fluids
Controls
Stomp grip
New grips
Crash protection
R&G frame sliders
R&G swinger sliders
Rad/oil guards
Engine
Race ECU
K&N air filter
NGK spark plugs
PSR blockoff plates
Mike
(315) 214-1958
