2015 Kawasaki ninja 300
Selling a 2015 Kawasaki Ninja 300 with ABS brakes, all stock. Salvage title but very minor damage. The swingarm had the most damage, but I replaced it with a nice one. Looked to me like someone hit it 2 or 3 times with an axe to get it totaled. Didn't even break the mirrors or a blinker. Runs really well, everything works as it should. 1400 original miles with new clutch friction plates.
Besides the cosmetic damage to the bodywork, the only damage it has is a ding in the front rim lip (holds air) that is easily fixable, and both bars have minor bends.
This would be an excellent start to a nice little track bike. Everything is straight and runs and rides well.
Located just north of Syracuse NY, Asking $2200 or reasonable offer. May be able transport or help arrange transport to Pit race or NYST.
Also the shifter is bent but useable and the brake lever end is broken offWIN_20180516_16_01_38_Pro_resized.jpg
Piss off the wife
I have aprepped 250. Was curious if the parts convert over to make a prepped 300 and a clean title 250 left over
timmgold
Piss off the wife
If you have the last generation of 250 the answer is yes. I just did it. The motor bolts right in, you take the ignition rotor off your 250 and install it on the 300 motor, splice the harness coming from the 300 stator/cover ito your 250 wiring harness, put in 115 or 120 size jets your carbs and you're almost done. You also need an exhaust header from a 300 Ninja or you have to modify your 250 exhaust to clear the spin-on oil filter. (I modified my Area P race exhaust by cutting off the exhaust monting and welding in a half inch section to it. I think the easiest solution would be to just buy a complete aftermarket exhaust for a 300.
