'00-'05 GSXR 600/750 '07-'11 Ducati 1x98 Parts
Tractionless
Prices are shipped CONUS.
Suzuki
*Rear wheel, 5.5" w/100 mi. old cush drive rubbers, bearings dust caps etc., and valve stem, the white outline is only a sticker and removable.................................................................................$125.
*Left and Right fuel tank filler panels............................................$20
*Left side stock footpeg '00-'03............................................... ....$20.
*Right side stock heel guard '00-'03..............................................$20.
*ST Machine "R" logo head guards '00-'03......................................$40.
*Passenger rt. side stock peg/bracket/ex. hanger '00-'03.................$25
*Brake bar,stock '00-'03............................................... ..............$20.
*Yoshi. DB killer for RS-3................................................. ...........$30.
*Stock upper shock mount '00-'03............................................... .$20.
*White rim tape, complete set............................................... ......$20.
*Fuel tank lid stock '04-'05, will supply key....................................$35.
*Brake lever (1) stock............................................. ...................$10 EA.
*Misc. MSR clutch lever & perch............................................. ......$20
*Brake bracket........will throw in box w/other parts if ya need...........$0
*Front brake MC stock 600/750 '00-'03..........................................$30
*Rear brake res. (2)............................................... ....................$15 EA.
*'03-'04 GSXR-100 '04-'06+ GSXR 600/750 Front Calipers..............$50 pair.
*Vesrah RJL-17 front set PN: VD-349 fits GSXR750 (96-99), GSXR1K (01-02) TLR1000. 4mm marcel left (ie a ton) zero heat marks, street used 1k miles......................................................... $60
*Ohlins Shock springs- Both used on a Ohlins 3x clicker rear shock fitting '00-'03 GSXR-750 '01-'03 GSXR-600. Check the part numbers below as it may fit others. 01091-24/80 L038 & 01091-24-70 L038........$40 Ea.
*Fork spring (1)- installed in 25mm Ohlins internaled Showa forks found on '05 GSXR-750's. Check the part number as it may fit others, buyer responsible for fitment. 04744-95/L616.............$30
Ducati
'07-'11 848/1098/1198 ZG Corsa Windscreen 10/10 condition......... $75
Yellow Fender 8/10 condition........................................................ .$65
Windscreeen 8/10 Condition, usual light scratches, .........................$50
Tail Light 9/10 Condition................................................................$20
Rear turn signals minus connectors 8/10 Condition...........................$20
Ram air duct covers 10/10 condition...............................................$40
Fuel Tank filler panels 10/10 condition............................................$40
Sprocket cover 10/10 condition......................................................$20
Dashboard cover 10/10 condition....................................................$20
OEM rear brake disk......................................................................$50
OEM PP ........................................................................................$35
Surflex thick metal plates (2) 0 miles............................................. $20
Surflex convex metal plate 0 mile...................................................$20
OEM metal plates (6) 7,600 miles................................................... $20 EA or make package deal.
OEM friction plates (EA) 2.49mm-3.93mm ........................................$20 EA or make package deal.
OEM Steering Damper no leaks.......................................................$40
As you can see I won't make a trip to the PO for less than $20. If you'd like multiple $20 items we can strike a deal. Please check my feedback on Ebay username Tractionless. Thanks!
