YES! :notsure:BigBird;186282 wrote:
what are the recommended cold/hot pressures?
You're right... I thought i read something i didn't. A friend used q2's last year and I believe that's where I got those pressures from. I think he found the best pressures to be in the mid 20's cold... but I am going to ask to make sure.G2G;187137 wrote: It does not state the 32 32 is a hot pressure. If you don't know call. Steve B will tell you himself.
Your hot pressures are the same what I ran when I used Q2's!Bike handled nice,just be carefull when summer heat comes (95 deg. and up)Southerly;187087 wrote: Is that 32/32 hot? When I got the Q2s installed last year at the track I was told that the recommended pressure was 29r/32f hot which is what I have been running. Does it depend on the bike as well?
mikey or anyone else who's interested, this is directly from steve's post on the css forum.Mikey75702;187166 wrote: You're right... I thought i read something i didn't. A friend used q2's last year and I believe that's where I got those pressures from. I think he found the best pressures to be in the mid 20's cold... but I am going to ask to make sure.
interesting...when i used those types of air pressure, it felt like i was riding on an ice skating rink. it was so bad, i was ready to switch from the Q2s to any other brand of tire over lunch.Lonewrench;186549 wrote: 32/32
I just made the switch to Q2's and I sure hope I dont see this myself!Fastguy;187286 wrote:
The Q2 rear seems to "separate" (for a lack of a better term) in the tread area. One explaination that Ive heard was that it was from flipping the rear.
Rob, it is my understanding that the separation you see if from the angular joining of the surface rubber. I first learned of this when reading about Dunlops made in Europe VS US made rubber. The angle which they are joined was the given reason that you should not flip a US tire.Fastguy;187286 wrote: Well I have a question that Ive posted and asked a couple of times before but have not gotten a reasonable explaination.
I currently have a rear that I have not flipped thats beginning to "separate".
Other riders have indicated that they too have had this issue happen. I dont think that I can run over something with different sets of rears.
+1BigBird;187259 wrote: interesting...when i used those types of air pressure, it felt like i was riding on an ice skating rink. it was so bad, i was ready to switch from the Q2s to any other brand of tire over lunch.
Someone told me to aim for 31F/29R HOT pressures and that made the tires felt 1000% better. Since I've been using that pressure, i recommended these tires to everyone. They felt better than the 209s I was using.
I start cold pressures with about 23-25 pounds in the rear (depending on the weather) and about 28-29 in the front and the tires feel awesome when they warm up.
But I'm a lowly rider, so take it for what its worth.
