Olde English
Well, I went ahead and screwed up the most basic of installations and now I'm in a dilemma.
I was installing a class 3 trailer hitch for my Rav4 and I managed to cross-thread 1 of 4 bolts. What happened was the hole was rusted and the bolt would not thread. Well, it finally caught, but after cranking it half way, I noticed that it was cross threaded to the max. Like, it's going in sideways :doh::banghead:
So now I'm in a pickle. 3 of 4 bolts are in good and are torqued properly. Should I re-tap the cross threaded bolt or have it welded onto the car? I've never had any experience with getting either done so I don't know the costs or where to get it done.
The problem with retapping the bolt is that the hole in the trailer hitch where the bolt goes through is a tight fit and it would probably have to be widened and the steel is pretty thick.
Also, this is all taking place underneith a SUV so it makes it that much more difficult to work on.
I thought about getting it welded on, but I'm not sure if this is advised. Also, I'd like to have the option of taking it off one day if I don't need it anymore.
Are there any other options? I won't be towing anything larger than a 2 motorcycle open trailer.
Where can I get this type of work done? About how much would it cost?
Thanks everyone
Thanks everyone
