I have some forks springs and an Ohlins shock spring that I will never use again unless I drop 100 lbs. I doubt that will happen, so I might as well let them go.
I have the following fork springs:
Qty. 2 - .95 kg/mm with a length of 273mm
Qty. 2 - 1.0 kg/mm with a length of 260mm
Qty. 1 - .90 kg/mm with a length of 260mm
I also have an Ohlins shock spring:
Qty. 1 - 1.00 kg/mm with a length of 160mm
The prices for these are as follows and include shipping:
.95 x 273mm fork springs (pair) = $50
1.0 x 260mm fork springs (pair) = $50
.90 x 260mm fork spring = $25
1.00 x 160mm shock spring $60
Here are some shots of all the springs:
