Hey guys. All these parts are from my bike and a couple friends. Shipping is not included, Sorry. Lots of parts lots of years Some race stuff some oem. Look thru and let me know what you need. Also Im sure that most of these parts will fit other years and models but I'm not too sure. I only put the years i know will fit. If you have any questions you can call or text me or PM me. (8287340195) Im located in Asheville NC local pick up is an option! Also you can get me at the track. Next day will be at Road Atlanta may 24-26. I can bring any parts down for you. Here are the parts as follows!
03-05 r6 06 r6s Yamaha
OEM Break calipers w/ Lines no pads ………. $35
horn ………. $10
mirrors slight scuff ………. Sold
kickstand ………. $30
kickstand switch sensor ……….$15
fan ……….. $15
left controls (lights, blinkers horn) with cables………. $20
rear foot pegs ………. $30
Rear brake light sensor ………. $10
rear seat lock and latch with key ………. Sold
Rear seat needs recovering ……….. $15
head lights cracked plastics behind lens
over plastics it fairly shows ………. Sold
Fiat plastics red fiat stickers came off really
really only good for repainting and
and the tail section has 3 broken tabs
with a windscreen, i can text pics ………. Sold
OEM Shock full ass. ………. $40
Vortex rear sproket 520/45tooth ………. $45
520/44 tooth brand new! ………. $55
front gear 520/17 tooth ………. $20
Rental front sproket 520/16 T ……….. $20
not sure the brand 520/14 t ……….. $20
Now time for the motor on this bike…
The motor is going to be sold for parts. Unless you want the full thing for ………. $400
The motor has 20k miles the bike was a commuter bike on the track one day.
Anyway the chain broke and put a hole in the block. Thats why I'm selling
it. I bought a SS motor and don't need this now. If you don't see any
parts listed feel free to ask. Im not to sure what is on the motor but
i know that it has these parts!
OEM stater cover ……… $35
clutch cover ………. $40
timing cover ……….. Sold
engine motor oil pan sump ……….. $40
OEM water pump ………. $40
Starter ……….. $40
Timing chain gear full ………. $20
clutch motor engine plates basket ………. $40
Head comlpeat with cams cam shaft
With valves and cover (all) ……… $150
Engine transmission tranny gears ………. $150
06-07 R6 Yamaha
Upper mid OEM fairings 50th year
anniversary (Slight scuff) (left) ………… $20
(right) ……….. $20
OEM Brake light stock ………… $20
08 - 12 R6 Yamaha
Very clean stock seat ………. $75
Race bodywork Hotbodies superbike tail
with primer, Brand new, Was
mounted never used. W/ under tail ……….$100
04-13 R1 Yamaha
Vortex rear sproket 530/45 ………. $45
530/47 ……….. $45
front sprocket stock oem 530/17 ………. $15
Ohlins TTX shock spring 95 for 200lbs ………. $40
mirrors clean no scratches not OEM ………. $25
04 - 09 R1 Yamaha
Very low mile Puig tire hugger retail $170
Carbon look very cool ………. Sold
07 - 08 R1 Yamaha
OEM headers ………. $70
Stock form inserts 4 k miles ………. $35
Oem Stocke rear shock 4 k miles ………. Sold
09 - 13 R1Yamaha
OEM stock shock full 3k miles ……….. $40
04 - 05 Gsxr 600, 750 Suzuki
Swing arm with axle no damage ......... $30
Rear brake caliper w/ Bracket, w/ lines
w/like new pads ………. $45
real brake caliper no pads w/ lines w/
master cylinder ………. $45
stock seat OEM little dirty ………. $40
600 exhaust and intake cams w/ valve
cover, w/ cam piston sensor ……….$80
ignition coil packs (all 4) ………. $20
Clutch leavers Brand new never mounted X2……… $ 15each
06 - 07 Gsxr 600, 750 Suzuki
Right controls (kill switch, start) No cables ………. $20
Front brake calipers w/ master cylinder
w/ OEM lines no pads ………. $45
Sub frame rails left and right ………. $80
mirrors OEM crashed in working order
Blinker plastics cracked a bit ………. $35
Right side clip on ………. $15
Stock steering damper ………. $40
OEM rear seat recovered black ………. $35
gauge cluster 9k miles in working order
mount is broken ………. $100
Shifter linkage pedal lever shaft ………. $30
front axle ………. $15
Right fork leg perfectly straight ………. $90
Fiberglass upper and nose bodywork w /
windscreen small crack, repaired
and strong black painted N/A brand ………. $145
08 - 10 Gsxr 600, 750 Suzuki
Sharkskinz belly pan painted slight scuff,
not bad comes with 6 fasteners! ………. $100
Rights side OEM tail fairing Blue 750
scratches not bad or cracked
all tabs in place ………. $50
900rr cbr Honda
Not sure the year but a black front wheel
6 spoke no damage rim ……… $85
horn ………. $10
kickstand ………. $30
fan ……….. $15
Starter ……….. $40
06-07 R6 Yamaha
(right) ……….. $20
08 - 12 R6 Yamaha
04-13 R1 Yamaha
530/47 ……….. $45
04 - 09 R1 Yamaha
07 - 08 R1 Yamaha
09 - 13 R1Yamaha
front axle ………. $15
900rr cbr Honda
