My 600rr rear was bouncing around in a few sectionsTeamBeer;181875 wrote: Once I changed that rear I didn't feel them at all. I will be at Road Atlanta all weekend. Are there some wavey sections at Barber? It felt like I was bouncing in a few sections.
I have found if you move 2 -3 feet left of the curbing at the top of 4 there are no bumps. I honestly have never felt any at the kink,, but doesn't mean they are not there.TeamBeer;181980 wrote: Thanks! Those are exactly the places I was feeling the bumps.
jcrich;181983 wrote: I have found if you move 2 -3 feet left of the curbing at the top of 4 there are no bumps.
Yeah, if I moved a bit wide in 4, and short shifted into 4th gear going up the hill (Thanks JRA), I rarely hit the bumps in 4.
I was trying some passing on the exit of 11, by staying inside on the exit, and that was a mistake. I found that I really needed to take the line carrying me through 11 to the left curbing on exit and then make my way back to the right for turn 12 pretty far down the short straight. If I moved right aggressively (early) I was in an area of bumps. Not to upsetting, and didn't affect my turn in on 12, but I could feel it.jcrich;181983 said:I honestly have never felt any at the kink,, but doesn't mean they are not there.
Kevin
Forgot to add that in my original post. Thanks MattMatt;181925 wrote:
that tire is DONE!
physicistkev;181986 wrote:Gotcha. :cheers: Yeah the short shift up the hill is the way to go. The quickshifter makes it even nicer.jcrich;181983 said:I have found if you move 2 -3 feet left of the curbing at the top of 4 there are no bumps.
Kevin
