DFlowe;162181 wrote: I like the self mapping feature you get by using the AFM. You continue to refine the map you build by using it over and over again until the changes are very small. At the point, I disconnect the AFM and remove the oxygen sensor.
I agree with the keep remapping feature. I have done the following when doing new maps:
1) Run one session and see how the bike runs
2) Map for session 2 and apply the changes
3) Map for session 3 and apply the changes
4) Ride the bike...
I tend to agree/disagree with it mattering about what tracks you are out. Road Atlanta to Jennings.. no big deal. Miller to anywhere else or anywhere else to Miller you might want to remap. I know I had to....
Lastly, if you’re running race fuel make sure you remove the Oxygen sensor when you are not mapping because the race gas will mess up the sensor in about 500 miles (there is a reason Bazzaz sells just the sensor separate)
