dt4629;243545 wrote: Hi,
I'm a noob, 1st track day ever on 6/16 Roebling Rd. I would like to bring a generator for fan. I'm not good enough to start using tire warmers yet. What do you recommend? There are so many types. I afraid of getting one that's loud and annoying to others. Any tips would be greatly appreciated.
I did a search, and most of the threads were generators for sale.
First make it a quiet one or plan to pit well away from others. If you buy a non-quiet don't even think about "well I'll just run my generator a little bit and the guys around will be cool about it." They won't.
Secondly buy enough output so you can eventually run other items. I'd say 2K watts at least.
As for recommendations Yamaha's or Honda's quiet line will do. One's really no better than the other. It comes down to the Chevy vs Ford arguments.
Lastly buy the correct extension cord. I see this overlooked in the paddock again and again. You can't safely pull 1000 watts through a 14 gauge 100' wire. You should be OK with the fan but should you use warmers or any heavy load get the correct cord. Here's a quick guide:
Most warmer are rated around 1000 watts +/-. That equates to about an 8.3 amp draw. Since people regular run fans, radios etc bump the current load to 10 amps. So:
14 gauge wire = 45 feet max length
12 gauge wire = 70 feet
10 gauge wire = 115
When I pit next to someone plugged in and running warmers on a 75 or 100 foot cord I move items away from his generator and cord and prefer that he/she not run their cord under my truck.
Hope this helps.
Good hunting.
Reg
