JBZ1k
Ok, I'm working out of town and when I get home I'll only have three days to slam my bike back together before road Atlanta and I may have an issue so I want some ideas before I get home.
So...everybody knows if your front wheel is off and you show a relative your bike the only logical thing for them to do is squeeze the brake lever right?
So I put the wheel on, look at the calipers and make sure none of the pistons are out, remove the fill cap, and proceed to try and wedge some screwdrivers in between some old pads to push the pistons back to a width to allow for instillation. Easier said than done, normally this is easy but the only way they would go back in was if I bleed the fluid off.
All back together, pump them up, not worried about bleeding them because when I got the new pads I was going to change the fluid, let it set over night and the next day I go to move the bike and the wheel is locked up....scratch my head...wtf... So I feel the lever and it is rock hard. I let some pressure off the bleed screw on the caliper and its all good.
Now this has happened every day since I put it back together.
My plan is to loosen everything up, recess the pistons, replace the pads, replace the fluid, bleed the system and hope it's all good.
But if its not I want some ideas about what else to check.
Btw the bike is an 2010 zx6r, 2,200 miles, fluid was a little less than half up on the canister.
Thanks!
Thanks!
