Gorecki
Alright, after running some cleaner through my old dinosaur, letting it sit and firing it up, the commonly seen smoke from such cleaners started emitting from the belly of the bike, great, I’ve got an exhaust leak!
The leak is right at the back side welded seam of where the 4-1 pipes come together. Be it a result of crash damage or a weld giving way over time, the leak is a fairly clean line across the bottom of the pipe, right at the weld.
I’ve attached an actual picture (best I could do) of the leaking area, and a pic of the same pipe with an arrow pointing to the actually location for perspective.
I believe this is an OE pipe but I’m not absolutely certain, it appears to be aluminum as there’s no rust but haven’t given it a magnet test yet to find out for sure.
Point in the post, what do I do? I assume the best solution is to have it welded but I’ve never had anything welded before. Know of a guy who has a MIG but have no idea if they can do it, or do it correctly. What would you suggest?
At the same time, I have an additional issue which may be directly related. After replacing the OE rear brake lever that I broke with the proper woodcraft, now there’s no space between the pipe and the bottom of the lever. When pushing the brake it pushes on the pipe.
This could be the pipe got pushed up, bending it upward and what caused the seam to split down below. I’m just not sure yet, but if it isn’t bent, how do I get it to fit properly with the new considerably fatter lever! Image also attached.
I'm trying to avoid buying a new header for a seriously older tracker.
