TRS mounting
Kruizen
How have ppl mounted pit-bull TRS if you have a tank directly under where you want to mount the plate? need to mount multiple plates.
thinking about mounting the plates to plywood and then mounting the plywood to the floor, this would allow me to only secure the plywood on the edges that gives me access on the underside of the trailer mount points, since the tank is in the middle.
what else has been done in this situation?
Something like these have worked for people in the past (obviously using the right size insert)
If you are at all able to access the underside of the floor, and set one of these in, they work awesome as well. I used these on my little Harbor Freight trailer for the wheel chock bolts (so I don't have to use nuts on the underside)
