'03 R6 (R6S) high RPM power loss
Hey all. I'm looking for some good ideas. I've been running thse bikes for years and know about the coil recall and problems. This symptom is similar, but coils have been replaced twice (despite testing showing they're good) and a new coil harnes has been tested and installed also/anyway. Fuel pump went from semi functional to dead while I'm diagnosing the problem, so that is new too. I've pulled the TPS, tested (okay!), cleaned anyway, reinstalled and adjusted. Plugs are newish. I have two of these bikes and spares, so parts swaps are easy at home or at the track. CDI has been swapped to two others with no change in symptom.
Symptom: At high RPM (12k & 14k) there is power loss. Power returns if I back off slightly from full throttle...like a carburetor. This does not happen when the bike is cold, but seems to get worse when it is hot and into the 3rd session of the day. The symptom is not consistent, making it a challenge to diagnose. It can only be replicated in a track environment, furthering my challenge to properly diagnose and repair it.
Open to good ideas from parts swaps to try, to diagnostic help. Bobblehead? Pit Lane Moto? Bueller?
Would really appreciate the assist. Thanks!
I'm no expert, but if your looking for ideas I would check fuel pump assy. Might not be heat related, but possibly fuel level (Assuming you don't refuel until after the third session). I've had some issues with fuel pumps reading accurate pressure at idle then at higher RPM dropping off and displaying symptoms of a misfire/power loss. Check pickup and hoses for clogs/cracks as you might be losing fuel pressure. Let us know what you find.
Thank you for the idea. I fill up between sessions and this is the third fuel pump/tank I've tried without affecting the symptom.
This sounds similar to a crankshaft position sensor on the way out in a car (called a pickup coil if I'm not mistaken, on the R6). Maybe give that a look.
Thanks. It is worth a look. Plannign to bring a few spares to my next track day to help diagnose. The hardest part is that it only fails at speed (and RPM), so it is one part at a time AT a track event...
That model uses a CV style slide in the throttle body (diaphragm type), It sounds like you've got a pin hole or perhaps the rubber dried and got hardened on one or more of these diaphragms preventing the slide to open fully.
Thank you for that. Would it fail so intermittantly with that issue? Twice yesterday it would turn over and but not fire, like it was getting no fuel. Symptoms are the same with the Power Commander connected and disconnected.
Not sure about that, but it makes sense that it would run better when cold. If the slides aren't opening all the way, the bike is going to run richer. Cold engines like that. Hot engines...not so much. I would take advantage of the no start situation and use that as an opportunity to determine if the issue is fuel system or ignition related.
So, a few track days later and problem still exists. I'm mostly riding around it, but would like to solve it. So far, with no change in symptom:
Tested all coils twice. They test as okay cold and hot, but still swapped twice.
Tested short coil harness. Tested okay and still swapped.
Checked plugs. Burning perfectly, set properly, look great. Recently replaced.
Tested TPS in bike and spare. Set/adjusted/clenaed both. tried both.
Fuel hoses fine. Vents fine.
Swapped ECU with other bike. Problem didn't move.
Swapped tanks/pumps. Problem didn't move.
Ran with and without PowerCommander with no effect.
Next steps aiming at engine cutoff system, lean sensor and kickstand switch (bypassed by other owner and may be grounding out???)
Open to great ideas. Intermittant electrical gremlins are the worst!
These model years have coil issues and they have a recall, but all coils I've used are the newer ones, test good hot and cold, and I've now had 3 different sets in there, so that type of failure seems unlikely. It is really strange...definitely feels like coil system, but I've been at it for about 4 months now... Probably needs a Honda sticker.
It wasn't a recall...just a service bulletin. That does raise another point. The coils you swapped with, are they the EXACT part number, correct, coils? Some of the newer R6S and R6 models have TCI ignition and similar looking coils but different resistance across the coils. I have seen the old style R6 coils installed into a newer style R6 which smoked the ECU in short order. I certainly could see where issues could arise if the TCI coils were installed in the older model.
Correctamundo. All verified as correct items and measured cold and hot, primary and secondary.
