hoppa2k6
Didn’t get what ya wanted from Santa? Hoppa is here to help!
I am parting out SOME of this beautiful garage queen. Bought this bike off a fellow forum member for a build my buddy and I are doing. He's got a vision for it, so some stuff is staying on the bike, other stuff is being removed and is up for sale. Most of the parts off this bike are nearly mint as the bike was built up and spent all it's time on the stands... never got to see the track..
Previous owner had intended on building up the motor's lower end but then life happened and knew I could find the right home for it. Also adding a few other goodies in this thread in case you overlooked my other thread.
Prices include shipping unless otherwise noted. YOU PAY FEES IF USING GOODS PAYMENT OR ADD 3%
Here’s some of what’s available:
BST Carbon Fiber Rims (SUPER CLEAN RIMS! - rubber available at addition cost - no rotors included) - $2000 (plus actual shipping costs)
Full Sharkskins with Sebimoto/HRC tail and Andrew Swenson HRC Isle of Mann TT style paint and Puig double bubble screen - $800 (plus actual shipping costs)
Ohlins 30mm NIX Retrofit Kit with Kyle Racing Ohlins Fork Cap Extenders- $1200 (plus actual shipping costs)
Ohlins PRXLS HO 3467 Shock - $750 shipped
Ohlins 68MM Steering Damper with custom fork tube/frame mount) - $400
Brembo SS P2 Rear caliper w/Ladybird Underslung Kit with Custom Length Spiegler Brake Line - $800 shipped
Spiegler Brake lines - $100 shipped
Spiegler Clutch line - $50 shipped
Arrow Dual GP Replica exhaust system (minty condition...no rash - mount for stock subframe, missing a few springs) - $1200 shipped
Gilles Rearsets, carbon fiber - Black set sold, have gold set available - $250 shipped
Gilles Tooling Shift Support Bracket - $60 shipped
Gillies chain adjusters - $200 shipped
Ten Kate / Febur Aluminum Race Radiator with Custom Oil Cooler - $1500 shipped
HRC Speedometer with HRC serial cable and HRC software - $500 shipped
HRC Quick throttle kit with Renthal firm grips- $150 shipped
Quick-release clip-ons - $100 shipped
HRC Bottle catch set and aluminum mounting bracket (allows you to run two catch bottles and mounts the BAS) - $100
HRC Endurance tank with HRC Fuel Pump kit - $1000 shipped (only fits aftermarket subframes)
HRC Subframe - $750 shipped
HRC Swingarm, HRC Suspension linkage (P4), and HRC Chain fin - $500 shipped
HRC triple tree - $500 shipped
A-Tech Intake - $175 shipped
Carbon Fiber Race Fairing Stay - $200 shipped
Carbon fiber rear fender - $150 shipped (pictured one sold, have another one available, pix upon request)
Carbon fiber front fender - $150 shipped (pictured one sold, have another one available, pix upon request)
Black TSR Clutch Slave - $150 shipped
SIlver TSR Clutch Slave - $150 shipped
Galfer rear wave rotor - $100 shipped
Gilles Chain Adjusters w/ lifters (Captivated - some rash on one) - $125
Gold Lightech Keyless Gas Cap - $55 shipped
Blue Lightech Keyless Gas Cap - $55 shipped
Accuman gear indicator - $65 shipped
Magical Racing carbon dash surround - $100 shipped
Nicky Mod Sprocket Cover - $50 shipped
OEM Speedometer with White backlit led mod - $200 shipped
HRC Deep Sump Oil Pan, Pickup and Relief Valve - $1000
Ladybird Underslung Caliper Hanger (for 84mm calipers - no caliper included) - $200
Sebimoto Fiberglass Superbike Seat for Stock Subframes (never used, not even painted yet) $120
SpeedoHealer - $100
Speedometer with 17083 miles on it - $200
Bill of Sale Frame - $500
Dynojet Power Commander III / Ignition Module / Quickshifter (GP shift) - $500
HRC JSB ECU - $300
Custom wire harness done the correct way (over 1lb lighter than HRC). Completely pulled apart and resoldered. Accumen Gear Indicator Integrated/Hardwired into harness - $500
Galfer clutch line - $50
Woodcraft swingarm toe guard / sharkfin - $40
08+ CBR monoblock calipers (great upgrade for 04-07 1000rr's and 600rr's!) - $100
Custom Galfer SBK front brake lines - $100
Captivated Carrozzeria/Brembo underslung rear caliper - $300
Woodcraft clipons - $100
Motion Pro Throttle $100
Gilles Chain Adjusters w/ lifters (Captivated - you'll need to drill out your swingarm to use these unless you want this swingarm too..) - $125
Lightech Keyless Gas Filler - $50
Carbon front fender (light chips on at front edge) - $100
Magical Racing carbon dash surround (light chips on bottom left edge) - $100
Motors available:
Erion Racing (ex Josh Hayes) superstock motor (comes with HRC velocity stacks, Hinson slipper clutch, Factory Pro star shift kit, Woodcraft Stator cover and Woodcraft clutch cover protector) - $1800 plus actual shipping
2006 Motor with the following work done - $2500 plus actual shipping
Yoyodyne Slipper Clutch with Barnett Clutch Kit
HRC Velocity Stacks
HRC JSB ECU
HRC Thermostat
HRC JSB Wire harness
SpeedoDRD-S1 Calibrator
HRC Bank Angle sensor
HRC Speed sensor
HRC Winker switch
HRC Alternator
HRC Oil Catch Tank and Breather Case
HRC Breather hose
HRC Deep Sump Oil Pan kit
BMC Air Filters
PAIR Block-Off plates
FLO S.S. Reusable oil filer
182HP (via MR12) Erion Built Motor
This thing is the beez kneez of built motors. Have all the receipts and dyno work to prove it. Hasn't been refreshed in years and it's still putting down solid numbers. On MR12 it was putting down 182HP and on u4.4, it was putting down 176HP. Refresh the motor and you are looking at close to 200.
14.7:1 Compression Ratio with Titanium Con Rods and Rod Bolts from Ten Kate, CP 75mm High Comp Pistons, Erion Cams, HRC Valve Springs, HRC Air Funnels, Yoyodyne Slipper, Vance and Hines headwork, BMC Race Filters, Woodcraft Stator and Clutch Covers, etc etc etc.
- $3000 plus actual shipping
Brand New Motor Build Kit - $2000
Wiseco Pistons, Rods, HRC Valves & Extra head
more pix upon request...
SpeedoHealer - $100
HRC JSB ECU - $300
Motors available:
HRC Velocity Stacks
HRC JSB ECU
HRC Thermostat
HRC Speed sensor
HRC Winker switch
HRC Alternator
HRC Breather hose
BMC Air Filters
