chidadog
Ok here it is guys. This list is very extensive so check it over. It's also listed here http://home.comcast.net/~chidadog/site/ be sure to check the website for the most current availability. If you need pics please include your email and I'll gettem right to ya.
Thanks for stoppin in
Pat
04 R6 On Bike Parts
2 Front Rotors $80
Rear Rotor $20
Rear Rim Black $150
Front Axle $15
Rear Axle $15
Front Spacer $10
Rear Spacers $10
Set of Stock Calipers Front Safety Wired………65
Rear Caliper……………….25
Stock Rear Brake Line…………………………………10
Rear Master with Reservoir……………………………20
Clutch perch and stock lever……25
Ignition with key……50 (will work on any r6 and r6s 03+)
Battery Tray…..25
Rectifier……75
Throttle Bodies……100
Airbox with Filter……50
Frame Bill of Sale..MSO never registered…650
Swingarm……35
Lower link…..55
Seat…………..50
Extra 04 R6 Parts
2 used Front Rotors - $80
Used Rear Rotor - $20
Set of Stock Rearsets Bent shift lever that can easily be bent back - $65
Stock Front Brake Lines - $20
Set of Stock Calipers Front - $50
Rear Caliper-$30
Stock Brake Lever - $10
2 Stock Clutch Levers - $8 Each $15 For both
New In Package Gaskets:
Swingarm Seal Guard 5SL-22151-00 ……………….10
Cover Pinion 5SL-15463-00 ……………………………..2
3- Oil Pump Cover 5SL-15456-00 ……………………5 ea
Cam Tensioner Gasket 4FM-12213-00…………….2
Crankcase Cover 2 5SL-15461-00 ……………………5
Crankcase Cover 5SL-15462-00………………………..2
Crankcase Cover 1 5SL-15451-00……………………...3
Blue Tank Right side dent rounded dent not sharp…….50
New Stock Air Filter…………..20
Open Stock Air Filter………10
__________________
Pat
04 R6 On Bike Parts
2 Front Rotors $80
Rear Rotor $20
Rear Rim Black $150
Front Axle $15
Rear Axle $15
Front Spacer $10
Rear Spacers $10
Battery Tray…..25
Rectifier……75
Swingarm……35
Lower link…..55
Seat…………..50
Extra 04 R6 Parts
Rear Caliper-$30
__________________
