Hello!!! I know this is my first post but I was referred here from the AssfaultJunkies forum, so you can blame them! Ha!
Anyways I'm selling an 05 GSX-R 600 race bike [no title but there is some manufactures paperwork]. The only reason I'm selling is because I like my RC51 more! Runs and handles great!
$2600
It has:
-'03 GSXR 1000 front forks [stock internals]
-power commander
-quick shifter
-Fox rear shock
-BMC racing air filter
-quick turn throttle
-rear sets
-hindle exhaust can
-racing gas cap
-Scotts steering damper
-race faring stay
-new wheel bearings after powder coating
-NEON green rims
-cast iron front brake rotors
-safety wired for the most part [I think everything is drilled is not wired]
-This thing is pretty damn quick!!!!
EXTRAS!!!
-brake pads
-2 extra rear rims with tires
-1 extra front rim
-3 extra sets of levers [one brand new adjustable MotoZen set from AFJ shop still in the box]
-water pump
-engine side case parts
-front brake rotors
-oil filter
-under tail with wiring
-starter [i think that's what it is]
-miss matched set of rear sets
The Bad
-steering damper needs to be refreshed, it doesn't work all that well [no leaks]
-secondary set of butterflys in the throttle bodies don't work and are unplugged, bike runs fine without them but the FI light is on. This is a common problem on these bikes
-rear sets and frame sliders are a little ground down
-exhaust pipe is slightly bent [I got rear ended at the track]
-Tach cover is broken but it works just fine
-belly pan can only be mounted with zip ties
ALSO if you want to buy just want piece................buy the entire damn bike and part it out yourself!!!
$2600
It has:
-power commander
-quick shifter
-Fox rear shock
-rear sets
-hindle exhaust can
-racing gas cap
-race faring stay
-NEON green rims
EXTRAS!!!
-brake pads
-1 extra front rim
-water pump
-front brake rotors
-oil filter
The Bad
