chidadog
2005 GSXR 1000 Full Race Part Out
THE GOOD STUFF
Forks with Ohlins Internals 6 track days on freshening Markbilt ……575
Ohlins SU503 6 track days on freshening Markbilt……………..650
NEW Ohlins Damper……………………225
Driven Clipons 50mm……………………SOLD
Driven D3 Grips Black………………SOLD
Driven Black Axle Adjusters w/ Sliders…………SOLD
Driven Swingarm Spools…………………20
Driven Black 520 Sprocket 44t……………45
Gilles Tooling Black Rearsets w/ CF heel guards…….275
Gilles Tooling Titanium Shifter Brace Gear Shaft Holder………..60
ASV Short Clutch Lever Black Gold adjusters…..65
GP Tech Black Folding Brake Lever…………….75
Stock Black Brake Lever……………….20
Galfer Rear Rotor…………………75
Spiegler Rear SS Line Black…………….40
Spiegler Front SS Lines Black………..80
Front Carbon Fiber Fender slight checking on front………55
Rear Carbon Fiber Hugger…………...65
Fairing Stay……………………….90
LightTech Black Keyless Gas Cap……SOLD
Vortex 17t Front Sprocket……………10
Vortex Rearsets Black….Bent can be fixed with a vice needs shifter bearings……..100
Woodcraft Left Side Engine Cover w/ Blue Slider little rash on Blue pad…………120
Woodcraft right side case saver………………100
Woodcraft Frame Sliders one side cut for fairs…………..45
Dynojet PCIII…………………..200
EK 520 MVXZ Black (nice chain)…………………………….80
Black M4 Slipper Exhaust small rash on cone…………….SOLD
Corbin Seat .. SOLD
TechSpec Side Grips with Side Panels (tank and lower side)……SOLD
BMC Race Air Filter…………..50
Lithium Ion Battery Pack 1 ½ yrs old. Works perfectly………….100
SharkSkinz Black Fairs w/SS Tail…………………….SOLD
Puig Clear Double Bubble…………………….SOLD
Titanium Bolt Kit Rotor bolts, Caliper hardware f&r, r axle nut, f axel bolt, pinch bolts, swingarm retainer collar and swingarm adjuster bolts and nut…………..90
Black Top Clamp Nut ……………………15
THE STOCK STUFF
Front Fender……………………………SOLD
Ignition and key …………..85
Frame Clean Title In Hand 1 Owner………1600
Engine 14070 mi. Valves done @ 13k……SOLD
Throttle Bodies………………………….85
Air Box…………………………….25
Radiator ………………110
Swingarm………………………30
Gauge Cluster w/ CF 14070 mi…………140
Throttle Accessory…………….40
Clutch Side Accessory……….40
Triple Tree Complete………..90
Lower Links……………………………10
Rear Master……………35
Front Master w Reservoir…………90
Front Calipers………..80
Rear Caliper………….25
ECU……………………….100
Main Harness…………..85
Front Short Harness……40
Rear Short Harness……..25
Seat……………………….25
Carrier……………………30
Front Spacers…………15
Rear Spacers……………...20
Rectifier…………………………65
Stock Fan……………………10
Front Axle………………….20
Rear Axle…………………..20
Battery Tray……………..20
Kickstand ………………...35
Ram Air Tubes………………50
Small Rear Fender……....10
Front Rotors………………SOLD
Rear Rotor……………….35
Rear Wheel ………160
Stock Front and Rear Brake Lines……30
Brake Lever………..9
Clutch Lever………..9
Subframe Complete……..225
Chain Guard 2 piece…………..25
Front and Rear Sprockets………..40
Stock Forks………………300
Stock Fork Cartridges…….150
Front Rim Only……………..250
THE GOOD STUFF
Corbin Seat .. SOLD
THE STOCK STUFF
Radiator ………………110
Swingarm………………………30
Rear Master……………35
Rear Caliper………….25
ECU……………………….100
Seat……………………….25
Carrier……………………30
Front Spacers…………15
Stock Fan……………………10
Rear Rotor……………….35
Rear Wheel ………160
Brake Lever………..9
Clutch Lever………..9
