Well, that'll make life easier for yohoho! Cool.27Ducati;239057 wrote: On your bike (05 R6) the brake fluid reservoir attaches to the top triple clamp so adding aftermarket clipons shouldn't be an issue.
Just got home and looked at the bike, 27Ducati's dead on, no need for the extra bracket. Looks like factory handle bars are around a 7 to 10 degree offset, coming straight out of the forks. So both Vortex and Woodcraft should be fairly close geometry.27Ducati;239057 wrote: On your bike (05 R6) the brake fluid reservoir attaches to the top triple clamp so adding aftermarket clipons shouldn't be an issue.
for track use I think you'll like them being mounted under the triple. Can anyone offer him some advice on the fork height? My only reference is on the newer bikes where we run them flush with the top clamp or with one line showing above.yohoho;239441 wrote: OK thanks, may try the basic woodcraft clip-ons and if those feel too low, can make someone a good deal on the lower risers and buy the taller ones. Looks like they go all the way to 3", that should be higher than stock if necessary.
Just took this pic of (what's left of) the factory setup, not sure if its my inexperience but the bike already feels like it wants to push through and stand up in the turns. Some recommendations on fork height would be great!27Ducati;239559 wrote: for track use I think you'll like them being mounted under the triple. Can anyone offer him some advice on the fork height? My only reference is on the newer bikes where we run them flush with the top clamp or with one line showing above.
yohoho;239595 wrote: Just took this pic of (what's left of) the factory setup, not sure if its my inexperience but the bike already feels like it wants to push through and stand up in the turns. Some recommendations on fork height would be great!
JohnS, thanks for the good info, since my triple is notched to allow for the stock handle bars, do I measure from the top of the highest point of the triple or the top of the lower notched area? right now those two measurements are 20mm and 30mm respectively.JohnS;239652 wrote: That looks pretty much stock or slightly raised already, On an 03 it was 24 or 25 MM from the triple to the bottom of the cap for stock. To get the bike to turn in faster and feel more planted you would want to raise the fork tubes in the triple 5mm to 7 mm. I would not go much more than that as the bike can feel less stable on the straights.
Also aftermarket clipons are much wider the then stock one, if you try to put them on top of triple more than half of it will have nothing to clamp to.
That would be measured from the lower notched area, Since you are at 30 already it seems someone has already raised the forks 5MM. I would max go 2 or 3 more install the clip ons and get the suspension baseline set up, you might find out from the suspension guy you are too light or heavy for the stock spings. If so you might just be trying to get it good enough without putting meney into the suspension.yohoho;239686 wrote: JohnS, thanks for the good info, since my triple is notched to allow for the stock handle bars, do I measure from the top of the highest point of the triple or the top of the lower notched area? right now those two measurements are 20mm and 30mm respectively.
Thanks, I am probably too heavy for the stock setup also, will add to the top of my upgrade wish list.JohnS;239721 wrote: That would be measured from the lower notched area, Since you are at 30 already it seems someone has already raised the forks 5MM. I would max go 2 or 3 more install the clip ons and get the suspension baseline set up, you might find out from the suspension guy you are too light or heavy for the stock spings. If so you might just be trying to get it good enough without putting meney into the suspension.
I was too heavy for my stock suspension so that cost me new springs in the front, race tech rebound and compression gold valves and a new rear shock. The bike handled much better after that!
