I have an 06 GSXR 600 that was meant to be put together for the track.
As you can see from the pictures,
Clean VIN and straight/undamaged frame but with salvage title I believe. Good swingarm and subframe. I don't have the title. Bill of sale only.
Ohlins R&T forks with calipers. Also rear brake caliper with brake reservoir.
HyperPro RSC steering stabilizers with mounts.
Extra Ohlins rear shock spring and a rear shock with Eibach spring revalved with Raceteck
Wheels with new Metzler Racetec tires
Vortex Clip on Handle Bars with throttle cables.
Gas tank and upper gas tank fairing (has a crack in the plastic): The tank does have a dent on the left side and a scratch on right side as seen in pictures, but there is no rust in the tank.
Seat has no rips, like new.
GSXR 600 Motor and extra head. Engine also has a hair crack on the case. Fixebale I suppose. I'll say engine is for parts mostly. Missing the clutch case.
A box full of bolts and engine mounts.
Other misc parts, rear sets that may fit, an ok radiator, etc.
No wiring harness, ecu or anything like that.
I'm looking to sell everything all together. Asking $2500
Make an offer.
Located in Raleigh NC.
Make an offer.
