06 GSXR 1000 A Bike Loaded Part Out Yosh, Brembo, Marchesini, Ohlins etc...
chidadog
Hey Gang
I've got the A bike to the B bike that I'm parting. This is loaded and I'll have prices of stuff up probably tomorrow. Short list..Marchesini, Brembo rotors, calips master, pads. Vortex LOCKING Black cap, rearsets, sprockets. M4 Full Ti Exhaust, Yoshimura Case guards, rearsets and UNAVAILABLE Complete Triple with 3 eccentrics on shafts. Bazzaz TC, Ohlins 25mm carts, stabilizer and rear su503 (46) Offset Swingarm Pivots etc...lots more so check back.
YouTube Vid http://www.youtube.com/watch?v=IxSuj3njBrs&feature=player_embedded
Here it is......Get ready to grab something to drink and eat to get through it all. I'm sure I missed some stuff so whatever you need just ask.
Stock Stuff
Inner Cowls………………..35
Ram Air Tubes…………….45
Rear Black Cowl………………65
Undertail…………..30
Front Turns/Mirrors wires cut flush…………..50
Gas Tank Black/Red left side dented…………..130
Gas Tank Orange Right side dent………………………..150
Small Tank Panels………….20
Large Side Panels ……………15 ea
Fuel Pump…………………65
Rear Turn Signals………………..65
Lock Set Ignition, Cap, Rear Lock…………..125
Triple Tree…………………100
Stock Damper………………25
Clutch Lever with Perch………………….25
Front Brake Master………………65
Rear Brake Master………………10
Stock Front and Rear Brake Lines…………10
Rear Rotor……………40
Front Calipers………………..40
Rear Caliper…………………20
Front Rim……………………..190
Rear Rim………………………100 Have a BUNCH
Gauge Clusters just ask…….120-160
Front Short Harness…………….45
Rear Short Harness…………….15
Main Harness…………………….80
ECU………………………………100
Rectifier……………………….75
Throttle Bodies……………85
Stock Titanium Headers………………..85
Air Box…………..20
Front Seat……………….25
Left Accessory High/Low Beam……………35
Frame R Title………………1100 HAVE A FEW FRAMES JUST ASK
Swingarm………………..45
SubFrame………………….175
Battery Tray………………….15
Front Axle………………….15
Rear Axle with Blocks………15
Rear Spools……………….10
Kickstand………………….40
Radiator……………….140
Oil cooler……………40
Stock Motor………………1200 Have a few one is SS as well.
Stock Exhaust complete…………..150
THE GOOD STUFF
SS Built Motor…………..1400
Marchesini 17" Alloy F & R Rims w/ Carrier and NEW Vortex 43T Sprocket………SOLD
Flashed ECU……………………….160
Race Tech Fork Internals ………………………400
Ohlins 25mm Carts……………….SOLD
Ohlins SU503 Shock…………………….550
Ohlins Steering Stabilizer…………SOLD
Brembo 19x20 Master……………230
Brembo 19 x 16 Master…………SOLD
Brembo HP Full Floating Rotors 310mm 70.1517-B ……………….450
Brembo Front Mono Calipers…………………SOLD
Carbone Lorraine Pads C59 NEW Front Set…………SOLD
Galfer Pads Rear FD325G1370 NEW…………25
Galfer SUPER BIKE SS Lines F…………….SOLD
Galfer Standard Black Standard Front Lines…….SOLD
Galfer 2-1 Black Front SS lines………………SOLD
Galfer Rear SS Black Line……….40
CRG Gold Shorty Brake Lever…………………..75
Woodcraft Stator Cover…………95
Woodcraft/CF Motosports Silver Rearsets………………200
Vortex Black Rearsets…………SOLD
Vortex Black Spare heel plates L and R…………10 ea
Vortex V3 Black Locking Gas Cap…………………SOLD
Vortex Rear Sprockets 42 43 44 46 51 etc… 20 ea
Vortex Front Sprocket 16T and 17T New IN Package……20
DID Gold 520 ERV3 and 520 MV Chain………..40 ea
Sun Star 42 Sprocket (Nice sprocket)………………40
Braking Rear Wave Rotor………………65
Yoshimura Case Savers L&R………SOLD
Yoshimura Black Rearsets…………SOLD
YOSHIMURA ONE OFF RACE TRIPLE R-K720-UC and LC with 3 eccentrics…SOLD
Sliders…………..25
Race Fairs not sure on make fairly clean 3 sets………………250 ea
Zero Gravity Clear Windscreen…………40
Zero Gravity DB Tint Windscreen Scuffed…………30
Offset Swing Arm Pivots…………….200
Sato 50 mm Clip Ons……….SOLD
Silver Clip Ons……………………SOLD
Motion Pro Revolver Quick Turn Throttle with cams…………SOLD
Motion Pro Starter Switch………………30
Dynojet PCIII…………………SOLD
Dynojet Ignition Module……………160
Dynojet STANDALONE QS Push……200
Bazzaz TC…………………….SOLD
Bazzaz Map Switch and TC Adjust…………90
Factory Pro Velocity Stacks……………SOLD
BMC Race Air Filter Cleaned and Charged…………………45
K&N Air Filter………………..40
Frame Sliders…………………..20
M4 Full Ti Exhaust Missing one flange………….275
Boz Slip On Exhaust…………….175
Dano’s QS Sensor set up for any Dynojet……………140
Ballistic 8 Cell Battery…………….85
Carbon Fiber Ram Air Tubes…………SOLD
Carbon Fiber Chain Guard (2 piece)………50
Carbon Fiber Shark Fin………………SOLD
Shark Fin.............20
chidadog
The CRG is for a stock. The two brembos I've got are standard levers. I think the 16 x 18 might be folding. I'd need to check though.
Usmtoddj
Interested in the swingarm if it is straight and has the spool brackets, also the yoshi case savers, and maybe a rear wheel. Can you see if there is any room to help on those items?
chidadog
SS Built. Port Polish Degreed Cams Milled Head. Freshened beginning of the season. ECU from Flash Tune. Setup for QS, TRE gear based timing retard elimination, 13850 rev limiter, pair valve disabled, top speed limiter removed, fan 205/195, high speed engine braking, low speed engine braking and a few other items in there
