06 GSXR 600 $4500 + ALL SPARES $6200
!ThatGuy!
2007 GSXR 600
Bike + one set of bodywork (your choice)= $4500
Bike + ALL spares= $6200 OBO
5968miles on clock, but speedo is not functioning. I have salvage title in hand. This is CCS expert racer Tony Leong, aka Push 186, previous race bike. The frame was swapped this past race season by myself and a professional mechanic. The bike has been down during races, so it has the battle scars, but everything is mechanically sound and everything is straight (except for left clip-on bar, it has a slight bend and fairing stay which I am replacing). I religiously change the oil with AMSOIL synthetic. I just winterized the bike so has new oil, anti-freeze, and clean/lubed chain while on battery tender. Located in Staunton, VA. Please contact me at: scracing200@gmail.com
Pics: http://imgur.com/a/iG8c7
Now for the goods:
The Bike:
•Supersport Motor build by Markbilt (March 2012) (From their site: R&R engine, blueprint, radius valve job, deck head & cylinder, degree cam, replace rod & main bearings, tune)
• MotionPro quick turn throttle
• Drilled / wired to CCS spec
• 520 Conversion with Vortex front/rear sprockets and DID chain performed in 2014 • Keyless ignition
• ¼ turn Vortex gas cap
• Forks refreshed in 2014 by a professional mechanic
• Traxxion extended Showa fork caps
• Traxxion Omni fork spring buffer kit
• Penske double clicker shock (refreshed by MDM in 2014, sprung for 190# rider)
• Full Leo Vince Factory R "Corsa" Ti exhaust
• PCIII and PC Ign Module with RnR tune performed in 2014, tuned for pump gas • PC Quick Shifter in GP pattern • K&N air filter
• FP Racing brake lever
• Goodridge SS brake lines up front
• Vortex Clips ons
• Vortex Rear sets
* Vortex fairing stay
• Woodcraft case and clutch covers
* Stomp grip
* SET Valve mod
* Secondary Butterfly Valve disks removed (sensor and rod still in place, but shows FI light, does not effect performance, I had RnR verify)
• Lightened rear rotor
• Vesrah SRJL XX brakes
• Rear brake reservoir delete
• Moto-D magnetized oil drain bolt
• Vortex swingarm spools
• Radiator guard
• Frame slider on Right side only (left side came off in a crash and I have not replaced it yet)
*Spark plugs replaced 2014
*Compression test done in 2014 and passed
••(I THINK that is everything, but I may have missed a few small things)
The Spares:
• Subframe back bracket
• Subframe rails
• SS brake lines front
• Set of calipers
• Rear rotor
• Several brake reservoirs
• 3 Vortex rear sprockets (new)
• 2 Vortex front sprockets (new)
• Brand new Vesrah SRJL XX front brake pads
• Woodcraft engine case guard with rash
• Brembo 19X18 front MC, has rash and a screw stuck in the mounting bracket
• Brembo MC repair kit
• Stock front MC
• Several stock clutch and brake levers
• Wheel bearings
• Vortex rear sets
• Radiator fan
• Stock throttle (complete)
• Motion Pro disks
• Vortex clip-ons
• Voretx rearset foot pegs
• Ballistic super lightweight 4cell battery
• Assorted bolts, brake pistons, bearings, etc
• 90 degree valve stems
• Sharkskinz upper and lower (upper has one spot of damage, can use as is)
• Armor bodies upper, lower, and supersport tail (damage, but all repaired, can use as is)
• Armor bodies upper, lower, and superbike tail (damage to tail and upper, can use as is)
• Sunstar used rear sprocket
• Front rim with rotors and rain tires with good life left
• Rear rim with rotor and rain tires with good life left
• Frame with damage (scratches and cracked along weld on right side. It can be repaired/ re-welded)
• Radiator for 2004/05 GSXR
• Stock seat
• Stock ram-air tubes (cracked)
• Gas tank with no pump and dented
• Brand new gas tank with pump and no damage
That should be just about all of it. Im really wanting to sell everything as a package deal. For EVERYTHING, bike+spares I'm asking $6200 OBO. Please contact me at: scracing200@gmail.com
Thanks,
Shad C
