tittys04
* 06+ forks off an 09 R6 with 25mm Ohlins kit, 1.025 spring rate. These forks are as fresh as you’ll find used forks, serviced by GMD in August, you can see the cross hatching on the tubes still. All bushings, seals and fluids were changed. $1050 shipped.
* 06+ Elka rear shock with .98 spring rate. It is a 4 way adjustable shock with hydraulic preload. I was absolutely amazed at how well it performed, was as good as an Ohlins for less. $750 shipped.
* 06-07 subframe. This subframe was cut to remove weight, then crashed and split in two. It’s been welded back together and is straight. $100 shipped.
* 06-07 swingarm. Straight, in good condition. $60 shipped.
* 06+ clutch cover. $20 shipped.
Pics here: http://weraclassifieds.com/ads/06-r6-parts-ohlins-elka-etc/#ixzz2kIAUBogB
