07 GSXR 600 AMA SPEC Part Out Marchesini Ohlins Brembo Yoshimura Bazzaz
chidadog
Just got this one in. Had been waiting for it for a while. A friend was building it over time and just gave up on it. Everything on it is NEW except what I have stated in the Good Stuff. I've got some stock stuff for it as well as others that are listed as well. He went way high end on this. The motor was built by Tom Housworth. Even the exhaust was picked up from Martin Cardenas's crew chief. Custom AMA built pipe. Beautiful coloring on it. Pics and list below. Need anything feel free to ask or email Chidadog@gmail.com
Tx Guys
Stock Stuff
Seat………….30
Ram Air Tubes…………….50
Gas Tank Blue………SOLD
Fuel Pump…………………65
Ignition w/key and cap …………..100
Clip Ons………………….40 ea
Triple Tree…………………100
Forks......................200
Radiator.................130
Clutch Perch………………….15
Clutch Lever..................10
Front Brake Master………………75
Front Brake Lever……..15
Rear Brake Master………………20
Stock Front and Rear Brake Lines…………5
Rear Rotor……………30
Front Rotor………….50 ea
Front Calipers………………..20/pc
Rear Calipers…………………15
Front Rim ……………………..200
Rear Rim ………………………150
Carrier/Hub (750) …………30
Front Axle…….15
Rear Axle………15
Front Spacer………10
Rear Spacers………..15
Gauge Cluster……………..150
Front Short Harness…………….40
Rear Short Harness…………….20
Stock Headers………………..60
Rear Muffler……………….50
Left Accessory High/Low Beam……………25
Right Accessory Starter…………35
Front Seat……………….25
Swingarm………………..45
Swingarm w/broken spool mount……..25
SubFrame with repaired but straight box………………….150
SubFrame Rails L&R……60
Battery Tray……….20
Black Undertail ……..10
Shock……………25
Links……………25
Kickstand………………….40
Stock Rearsets…………..45 ea
Shifter Assembly ……….35
Speed sensors……45
Turn Signal Relay…..20
Tank Side Covers..............20 ea
Front Fenders...........45
Rear Huggers........20
THE GOOD STUFF which is ALL NEW unless noted. The bike was never ridden
Attack Rearsets.... SOLD
Attack Triple with All Eccentrics......700
Bazzaz TC/ZFI.....SOLD
Bazzaz TC/Map Switch....SOLD
Bazzaz TC Light......SOLD
Bazzaz ZAFM.........SOLD
Bazzaz Zbomb TRE.....SOLD
Dynojet Ignition Module (used).........SOLD
Dano's QS Sensor for DJ Ignition Module.......150
Brembo RCS w/Folding Lever......SOLD
Brembo 19x20......SOLD
Brembo Reservoir........45
Brembo HP Full Floating Front Rotors 310mm 70.1517-B (used)....450
CRG SuperSport Clutch.......120 (Used)
Driven Gas Cap.....SOLD
Driven Gold Spools....SOLD
Driven Gold Swingarm Blocks/Adjusters with Sliders.....SOLD
No Cut Sliders.......40
BrakeTech Full Floating Front Rotors Axis/Iron 310mm.........600
BrakeTech Full Floating Rear Rotor Axis/Iron.......185
Braking Rear Rotor............SOLD
Ferodo Front Pads....SOLD
Spiegler 3-1 White Front SS Lines...........SOLD
Spiegler Rear White SS Line...................45
Remember all this stuff is NEW unless stated
M4 Full TI Custom AMA Exhaust (Martin Cardenas’s Bike) M36 but shorter can and mounted lower...SOLD
17" Marchesini Magnesium Rims w/Carrier and AFAM 43 T Sprocket NEW.....2800
Ohlins 30mm Carts Installed w/ 1.0 springs gold valving...SOLD
Ohlins Black Fork Extenders.......SOLD
Ohlins SU789 Mk 2 TTX Rear Shock Newest Model 1.0 Spring with Box.......SOLD
Scotts Steering Stabilizer New in Box.........SOLD
Vortex Black Stay.....SOLD
Yoshimura EMPro........475
Yoshimura Cable and software..........250
Yoshimura STR-S Cams w/adjustable sprockets.........600
Ported and Polished Head Mild Milling...........600
Woodcraft Right Side Case Protector.............SOLD
Woodcraft Left Side Case Protector..............SOLD
Votex Black Fairing Stay...................SOLD
Shorai 4871 Lio Battery..........SOLD
Ballistic 8 Cell Lio Battery (used)..........SOLD
Armour Bodies Fairings Unpainted or drilled...........SOLD
ChickenHawk Warmers Single Temp (used)...............275
NTEC Take Offs DOT 120 190/55 F/R UK’s 3 complete sets...........SOLD
NTEC Take Offs DOT 190/55 Rears 2.............SOLD
Kyle Racing Black Clipons...............SOLD
K&N Air Filter (used) Cleaned and Charged........35
BMC Air Filter (used) Cleaned and Charged.......SOLD
vinny337
Vin is in...Beastmode!
Pat, thanks for everything!! I encourage everyone that has a Gixxer to look no further!! TTT
