07 R1 Pro Series kit question...
hooligan998
I e-mailed Woodcraft directly about a week ago but have not recieved a response back as of yet, so I figured I would try here. My questions are:
1. Do the body kits come with a windscreen?
2. Can I use the stock windscreen?
3. How may dzus fasteners are required for the kit?
4. What other fasteners/grommets are required?
Thanks!
Thunderace
BIG JIM
1. No
2. Yes
3. I believe 4
4. You will need 4 mounting bolts for the fairing at the frame. Two will attach to the fairing stay. I believe there are 6 that hold the windscreen on. And two will mount to the back of the lower. I have an '05 R1 and that is how my bodywork attaches. The '07 should be quite similar.
hooligan998
The 07 and 08 windscreens do not use fasteners to attach. They slide into clips in the OEM fairings and are held in place by tension at the mirror mounts. So an OEM 07 or 08 windscreen does not normally use bolts like th 04 to 06.
lindr6
I bit late but, you will need to drill a few holes and windscreen bolt and well washers. I have an 07 and I drill four holes into any and all types of windscreen and I use zip ties in mirror holes to hold the upper in place.
