chidadog
[VIDEO]
Stock Stuff
New Recalled Front Master Cylinder…………85
Seat………….25
Ram Air Tubes…………….50
Gas Tank Black some damage to filler spout area not pictured………….200
Gas Tank Pictured………….200
Fuel Pump…………………65
Complete Key Set Ignition cap and rear lock…………..125
Clip Ons………………….40 ea
Triple Tree…………………100
Forks......................200
Radiator.................145
Clutch Perch………………….15
Clutch Lever..................10
Front Brake Master………………65
Front Brake Lever……..15
Rear Brake Master………………20
Stock Front and Rear Brake Lines…………5
Rear Rotor……………20
Front Rotor………….40 ea
Front Calipers………………..20/pc
Rear Calipers…………………15
Carrier/Hub …………30
Front Axle…….15
Rear Axle………15
Front Spacer………10
Rear Spacers………..15
Gauge Cluster 5060mi (lots just ask for mileages)……………..180
Fairing Stay………………..NEW……85
Front Short Harness…………….45
Rear Short Harness…………….20
Stock Headers………………..45
Rear Muffler……………….50
Left Accessory High/Low Beam……………25
Right Accessory Starter…………40
Harness………………..75
08 600 Frame with 5k mi ……………….1700
Motor with 5060 Miles……………..800
Throttle Bodies...........................85
ECU..............................140
Swingarm………………..45
Swingarm w/broken spool mount……..25
SubFrame complete………………….195
SubFrame Rails L&R 06 07……60
Battery Tray……….20
Black Undertail ……..10
Shock……………20
Links……………20
Kickstand………………….40
Stock Rearsets…………..45 ea
Shifter Assembly ……….35
Speed sensors……45
Turn Signal Relay…..20
Fuel Pump Relay……25
Tank Side Covers..............20 ea
Front Fenders...........45
Rear Huggers........20
THE GOOD STUFF which is ALL NEW the bike was never ridden
Flashed ECU......................200
Scorpion CF Shorty slip on with Cat Delete………….150
Two Brothers Shorty Exhaust (Not pictured)….175 PCIII……150
Danos Stand Alone Quick Shifter Pull (GP Shift)……….220
Bazzaz TC Unit…….575
Bazzaz Map/TC Switch……..85
BMC Air Filter……45
K&N Air Filter…25
50mm Clip Ons Silver………………….85
RaceTech 25mm Carts (In Forks) FRSP 54031 with Fork Extender……..675 comes with oem carts also
RaceTech GS 3 Rear Shock with Remote………….650
Ohlins Linear Steering Damper…200
GPR 4 Black Rotary Stabilizer…………….215
Ohlins 25mm Fork Caps…..75
Ohlins 30mm Fork Caps….75
Brembo Front Master Reservoir........45
Galfer Rear Rotor………….80
Galfer Full Floating Front Rotors DF48CW Just Put On……450
Pazzo Levers Black Shorty Silver Adjusters F&R…..110
Pazzo Black Long Clutch.......65 (Used)
CRG RC2 Long Black Levers red adjuster…………….110
Assorted Aftermarket Levers Short and Standard….Ask
SS Brake lines Front white silver or black Goodridge, Spiegler etc...............60
SS Brake Rear lines white or black...................35
Vortex Rearsets Black Folding Levers…………..240
Vortex Sprockets 45 Black……………25 Many others just ask
Track Fairs Upper Tail Lower and Fender……225
Pictured Track Fairs Black Yellow SBK Tail……………..275
Zero Gravity Clear Windscreen………..40
Clear windscreens…………..15
Race Rails Black…………75
Yoshimura NEW Harness….450
Vesrah SRJL Front Pads…………….85
Moto-R Black Stator Cover…….75
HPS Billet Stator Cover………..85
NRC Stator Cover……………..85
Myrtle West Lower Link SU105.............75
Clutch Case Protector Gold…….25
Stator Case Protector Derlin Slider………25
Woodcraft Sliders one rashed and broken……………35
No Cut Sliders…………………….45
Black OEM Rearsets and Passenger Pegs….140
Healtech Xtre XT-501 Timing Retard Eliminator……….55
Healtech Speedo Healer………………….60
Cox Radiator Guard Black…………50
Tech Spec Tank Pads……………..20
Dunlop NTEC 200/55 KR449 Rear…………….
Dunlop NTEC 120/70 KR448 Front…………
Take Off Dunlop NTEC Front 120/70 UK Tire…………
Michelin Pilot Power 3 180/55 120/70…………
