JTRC51
MINT condition and fully prepped 2008 R6 Track Bike, ONLY 1200 original miles and not a scratch on it. Extremely clean and wired (haven't done the wiring on the caliper bolts and lower fork leg bolts - but they are drilled). It needs absolutely nothing
Clean and clear title too (something not many have)
ATL area -
1200 miles with 5 angle valve seat job and thinner head gasket - Dynoed @ 118.6 on 93 pump (Shell premium) 8/2016
Sharkskinz Bodywork - professionally painted and looks as good as factory!
Penske Triple rear shock (550 & 600 lb spring as spare) refreshed by TMAN on 9/2016
Ohlins 20 Mil kit forks (.975) refreshed by TMAN on 9/2016
Full Ti - Graves Exhaust
Block off Plates
PCV & QS
Flashed ECU
Graves Rearsets (GP shift)
Scotts Damper
Vortex Clipons
SS Brake lines with EPFA EBC pads
Ballistic Batt
New OEM air filter with snorkel removed
Fully serviced and tuned - I did this because the bike had such low miles and sat for a while so I wanted it 100%
Steering head bearings repacked (greased), inspected and torqued
All other bearings inspected/serviced/greased
New spark plugs (OEM NGK)
Replaced watter wetter with Engine ICE
Injectors ultrasonically cleaned by Melka
Fuel system cleaner
New air filter
Coils inspected and tested
Brake fluid changed (Motul)
Fresh oil change etc...
Dyno'd @ 118.6 (8/2016) Pump 93
Bike has some of the OEM spares (clip ons, rearsets)
$8800 with spare complete wheels. Don't want the wheels? we can work out a less expensive price
OBO but serious inquiries only please.. No window shoppers.
I have pictures of the Original bodywork (Yellow) that was immaculate. An 08 this clean with this low mileage is hard to find!!
ATL area -
Block off Plates
PCV & QS
Flashed ECU
Scotts Damper
Vortex Clipons
Ballistic Batt
Fuel system cleaner
New air filter
