innovativemotorsports
The bike is a 1975 Honda CB360. I bought the bike is boxes and made it into what it is today. The bike rides, runs amazing, sounds great, and starts 1st kick. It does still have the electric start. Here’s a list of everything on the bike. No leaks and a true blast to ride. The bike is a 6 speed and cruises highway speeds very comfortably.
Compression is 125lbs in each cylinder. The bike pulls greats, idles smooth and has been up to a speedo indicated 90mph.
· CL360 head pipes (upper pipe extended to match the lower) & coated with high temp satin black
· Frame is de-tabbed
· Frame was stripped and base coated with POR-15 and top coated with POR-15 chassis coat
· New Front brake caliper seal
· Braided Front brake line
· Nissan Front brake master with shorty lever
· Shorty Black Clutch Lever
· Renthal Grips
· 1000rr start/kill switch
· 1000rr throttle
· Clubman bars
· Custom headlight bracket
· Custom Speedo Mount
· Triple Tree Lock
· Tanks coated with Caswell 2 part sealer
· Carbs professional rebuild and tuned
· Pod air filters
· UNI breather filter
· All wiring has been gone through
· New plugs
· New Fuel Lines & Filters
· New Chain
· Fresh Synthetic Honda Oil
· Custom fiberglass café tail with superbike style seat foam
· LED brake Light
· Tail removes with two wing nuts to access electronics
· Antigravity 4 cell battery
· Ricks Motorsports Regulator/Rectifier
· Front Fork Brace
· Ready for Rearsets
· Dupont Jet Black, Metallic Gold, and White Chromabase & clear paint
The tires should be replaced as they are weather cracked. I was going to run rearsets but the builder who makes them didn’t have his next batch ready yet. Bike turns heads everywhere and is a true blast to ride! The bike is getting new fork seals this weekend and dust caps on Tuesday(05.29.12). Bike is for sale locally also.
Clear title in hand and ready for the next owner. Please call with any questions at 515-230-9938
Here is a video of the bike http://www.youtube.com/watch?v=_wQz9sdCFIA&feature=youtu.be
· Renthal Grips
· 1000rr throttle
· Clubman bars
· Triple Tree Lock
· Pod air filters
· New plugs
· New Chain
· LED brake Light
· Front Fork Brace
