2000 R6 with 21,000 miles, runs strong and hangs with newer 600s on the track. Set up for 185lbs.
Fork springs .95 kg/mm
Ohlins shock
GPR damper
vortex 530 chain and sprocket 15/48
woodcraft clipons
woodcraft/ vortex rearsets
fiberglass bodywork-repaired
EBC HH brake pads
Stainless brake lines
newer clutch plates and springs
Ivan's jet kit
Yoshimura slip on
frame sliders
swingarm spools
good battery
The bike starts instantly and runs beautifully. Good midrange, very strong top end pull.
no oil consumption, valves in spec 500 miles ago. Shifts well.
The tank is dented from an off at Beaverun, no leaks. Frame is straight and i did one
track day after the off and no issues.
Will need a rear tire, front has some life left.
No lights but all connectors are sill there.
Leathers available also.
$2000 cash, gold, silver, and interesting trades considered.
Angelo 440-212-5351 call or text. Cleveland, Ohio area.
Thanks for looking!
Ohlins shock
GPR damper
woodcraft clipons
EBC HH brake pads
Ivan's jet kit
Yoshimura slip on
frame sliders
swingarm spools
good battery
Thanks for looking!
