2000 SV650 $3,500.00 firm located in Cincinnati, Ohio
No Title but it is clear I checked before I bought it. I have owned this bike since 2008. The bike is a solid race bike. I completely tore the entire bike apart in the winter of 2009 and rebuilt the entire thing. All bearings were replaced. The motor is a Spears motor with a 1mm overbore. All seals and bearings were replaced. This was built to last a long time, it has all the bells and whistles. I have the receipts for the rebuild and would be happy to provide additional information on the motor. Shock is a Penske 8987 which was rebuilt by Traxxion in 2009. It is sprung for a 220# rider plus gear. Front forks are stock and were redone with intiminators and 1.0 springs, 15 weight oil. The oil was refreshed last year. Present body work is GSXR and has been down a few times but is very usable and will all mount up to race. Still looks like a 6-7 out of 10. At some point it will need a new fairing stay if you want to keep using the GSXR bodywork but I have run it as is at trackdays and raced it with no problems it is just safety wired together on one of the stanchion supports. Motor is fresh. I only raced it one weekend and one lap before I broke my leg at Grattan in 2010. I sat out in 2011 and did two track days that year. I did about four trackdays last year. That is all the time on the motor since rebuild. I would be happy to give the specs on the motor just contact me. Bike has a newer set of slicks mounted, we can negotiate for additional new tires I have in stock. I also have two additional full sets of SV bodywork and a fairing stay that will go with the bike. I have a slipper clutch that I will sell for an additional $500. It is the good Yoyodyne model and works perfectly. I can include a set of tire warmers if needed at a negotiated price.
Equipment:
Woodcraft clip ons and rearsets.
Shift light programmed to light 500rpm before shift point
RSC steering damper
HMF full exhaust
Penske rear shock (sprung for 220#)
Intiminator’s rebuilt by Greg Spears for racing in front forks with 1.0 springs and 10w oil.
520 conversion
K&N air filter
Keyless ignition and gas cap
New battery
Woodcraft alternator cover
15/45 gearing Vortex sprockets
Daytona temperature gauge
XT Ultra Lap timer
Broken in on Dyno Oil, full synthetic since. Oil changed every other trackday
Jetted for pump gas, could run race fuel with new jetting.
Brand new clutch frictions and plates when rebuilt.
Presently fully winterized, tires stored in heated basement.
This motor would really run great with flat slides and a good dyno tune.
If the bike does not sell I may be interested in parting it out as the sum of the parts is worth much more than what I am asking.
Equipment:
RSC steering damper
HMF full exhaust
520 conversion
K&N air filter
New battery
XT Ultra Lap timer
