2005 zx6r
binx_19
I was trying to remove the frame sliders for replacemend and i broke the bolt in the Lock Nut on the right side, does anyone know if it is possible to just go to the hardware store and pick up a 10mm Lock nut for replacement?
dale.b
Which piece are you looking for? The locknut for the engine mounting bolt on the right side?
You broke the bolt, but you need a locknut? :notsure:
If you tell me exactly which piece you need, I may be able to mail you a spare one.
binx_19
I need the lock nut. that was a hell of an adventure to get that busted bolt out, completely destroyed the nut with drill and dremel tool.
it is 10mm x 1.25.
According to Ron Ayers
Part #92015-1189
If you have a Fuel tank Damper #92161-0274 i could use one of those too.
