$3875
Warm days are here!!! A/C is your friend ;-).
This trailer was easily pulled by a 2004 Nissan Frontier V-6 even when loaded with two motorcycles, E-Z up, food, water gear, etc.
The overall dimensions are 7.5' wide, 10' high and 17.5' long. The inside is 6' high at the center.
This is a single axle enclosed v-nose that has numerous upgrades. It has diamond plate on the ramp, down the center of the floor, at the threshold of the side door and on the lower part of the exterior of the nose. The Dexter drop axle has E-Z lube hubs; I installed new 4200 pound leaf springs on it last summer -- at that same time I also installed folding stabilizer jacks in the rear, new LED tail lights and LED fender lights.
There are numerous D-rings for tying bikes or gear down, I installed backing plates on the larger ones last summer. There are a couple Pingle mounts (one Pingle chock is included) in the front floor area. It is set up to bolt in Pit Bull motorcycle trailer restraints and Nice Raxx motorcycle stand holders.
The walls and roof are completely insulated and the roof is finished with Luan paneling. The floor is marine grade plywood. There are zero leaks in the roof or doors. The upper bunks are currently in our basement but will come with the camper -- they took up a bit more room and we didn't use them. The lower bed accommodates at least a queen sized air mattress, is very sturdy and folds up in seconds.
In addition to the shelving in the nose, it has two built in 110V lights, several interior 110V outlets and one interior 12V light. I installed an external 110V GFCI receptacle and master cut-off switch last summer. There is a new (2011 dated cylinder) dry chemical fire extinguisher mounted inside the door and a smoke detector near the roof.
The AC is a Duo-Therm 13,500 BTU that will freeze you out even on the hottest summer days at Talladega and it also has heat strips that keep the chill away. The crank up dome cover was replaced last summer. The Coleman electric cooler operates on either 12V or 110V, was purchased last summer and has been used maybe six times.
(678) 835-7384
This trailer came with many options from the factory:
30" Side door with bar lock
Non-powered roof vent
"D" ring set
Spare tire
Spare tire mounting kit
Dome light
15" radial 205 75R 15LR
24" Stone guard
3/8" Plywood interior walls
Medium Duty ramp door (spring assisted)
(678) 835-7384
"D" ring set
Spare tire
Dome light
24" Stone guard
